Old 01-15-2011, 09:55 PM   #1
Tommy Boy
bAaAM!
Tommy Boy's Avatar
CPU and RAM Usage Gagdet
What does this gadget mean?
During msn and online surfing mine says 3 - 10 percent CPU usage and 45 - 70 percent RAM.
I mostly understand the CPU usuage but im more confused about the RAM meter. Should it be low? be high?
thanks for any info!
Tommy Boy is offline   Reply With Quote
Old 01-16-2011, 05:01 AM   #2
specs?
Old 01-16-2011, 11:33 AM   #3
hadesm5
hadesm5's Avatar
I believe its called a widget, not gadget.
Your CPU usage will increase depending on how computation-intensive your tasks are. For example, if you are trans-coding a video your CPU will be fairly high.
Your RAM is used up when your apps need to store temporary data in memory. For example, if you have firefox running, RAM usage increases as the number of tabs open increases. RAM usage also increases when you have multiple applications running.
If you have many low intensity programs open (such as msn, acrobat) your CPU usage will remain low but RAM will be used up. In contrast if you only have one high intensity app such as photoshop your CPU will shoot up.
You can see how much CPU or RAM (memory) each app is using by checking in your task manager (or activity monitor for mac).
Post your specs and whether your system is 32 or 64 bit
hadesm5 is offline   Reply With Quote
Old 01-16-2011, 12:04 PM   #4
sirex
King Sirex
This is what you need to do:
Delete that widget.
Old 01-16-2011, 11:24 PM   #5
slemmer
Driving in the fast lane
slemmer's Avatar
yeah and you'll get some ram back.
'15 Ford F150 Lariat SCSB 4x4
'04 645cic
'00 740i Sport
Old 01-17-2011, 09:34 PM   #6
Tommy Boy
bAaAM!
Tommy Boy's Avatar
Hp G62 laptop, intel i3 M370 @ 2.4ghz
64 bit operating system
4 gb ram
Old 01-18-2011, 09:44 AM   #7
2slow2race
2slow2race's Avatar
delete the stupid thing.
2slow2race is offline   Reply With Quote
Old 01-18-2011, 01:02 PM   #8
Dysantic
Captain Chaos
Dysantic's Avatar
How much you wanna bet that widget is taking up half that RAM? lol
Delete it and don't look back. As long as your computer is running within what you find is fast enough don't think about widgets or any of that garbage.
Old 01-18-2011, 04:33 PM   #9
hockeyfan27
hockeyfan27's Avatar
4 gb ram
4Gb is the absolute minimum for a 64bit O/S.
There is a lot of discussion whether a 32 bit os on 3gb out performs a 64 bit with 4gb system as a 64 bit os uses more overhead.
I tried that widget, it is a resource parasite. ditch it, you'll be happier, I was.
If you are really curious, use the resource monitor in the task manager.
1998 328ic - Sold
hockeyfan27 is offline   Reply With Quote
Old 01-19-2011, 07:25 PM   #10
Tommy Boy
bAaAM!
Tommy Boy's Avatar
right on..i deleted it!
Old 01-20-2011, 09:19 AM   #11
NOTORIOUS VR
NOTORIOUS VR's Avatar
I've been running 64-bit OS's with 2GB of ram for years now... links that show why 4GB would be the min? It really doesn't matter IMO if you're 32 or 64 bit.
Old 01-20-2011, 03:04 PM   #12
2slow2race
2slow2race's Avatar
im running 4gigs with a 64bit o/s and it runs great.
never heard of that before.^^^
