Old 01-16-2011, 05:16 PM   #16
Actually, I suppose this is the most important question:
Why do you want to control fuel? If you're looking for more power, drop in a MarkD chip with high-test fuel and call it a day.
Old 01-16-2011, 05:57 PM   #17
bmwconnect
BMW Tuner
bmwconnect's Avatar
ughson
If it's NA power your after and you don't plan on making major changes to the motor in the future then a tuned chip for NA is your best bet
I also offer a chip upgrade solution for the M20
Old 01-16-2011, 06:07 PM   #18
ughson
Honestly the only reason I would do the standalone is so that I would learn more about the setup. The reason I would want to try ViPec V44 is that my FSAE team for school has one and I'd like to understand its setup. So at first a standalone for me wouldnt be doing much for performance. It would just allow for more down the road
This all started as me not being able to find anything like the SAFC or power commander for the m20 as I do want to turbo it but still want to have the opening to make changes. My plans for the turbo would be to get a t3 flanged t25 from a rb20det for the initial setup and then furthor down the road switch that for a Holset HX35; so I dont think I want a chip because I want to be able to change the fuel to componsate for different boost, injectors, MAF or MAP etc
ughson is offline   Reply With Quote
Old 01-16-2011, 06:26 PM   #19
bmwconnect
BMW Tuner
bmwconnect's Avatar
If you plan on going with the turbo setup and plan on changing the setup later down the road then you have a few different routes you can take
forget a piggyback unit because you will learn a lot more if you take on any three I have listed below
1. Mega squirt ( Most user friendly with tons of background support )
2. Miller War Chip ( very limited to what you can control )
3 Eprom emulator with tunerpro software( full control over stock ecu but with limited background support )
Old 01-18-2011, 06:08 PM   #20
ughson
^^ okay I think megasquirt is what I would want.
Above they talk about using the pnp from DIYautotune and rotate between ECU's what would be required to use MS1 tho and still do a similar technique? it has a completely different conection so do I just wire in and adapter?
Old 01-18-2011, 10:07 PM   #21
http://www.diyautotune.com/catalog/b...pcb-p-194.html
Or just gut an ecu and install the MS directly into the case. Why MS1 though when you can get newer versions with more features and better processing capabilities.
Another thing is rotating between ECU's will only work if you keep the AFM in the car once you go turbo you will hopefully get rid of your afm. After that you can't really switch back and forth between ECUs like I was mentioning. Yeah the car will still start on the stock ECU, but it runs just enough for the purposes of moving the vehicle, the car shouldn't be driven. However once you have the car tuned N/A in terms of starting and idling going over to turbo isn't that big of a deal, just upload some new fuel and timing maps and you're pretty much good to go.
Old 01-19-2011, 05:00 PM   #22
ughson
there is a guy on son240sx.org selling his ms1 setup... If i can get it for cheap enough then it makes sense to me to setup using this and upgrade the chip to ms2 later. If not I will prob get the ms2e DIYpnp kit and assemble it myself
I still plan on using a friends SAFC 2 and see if I can get it wired in and running because by far that would be the cheapest option
Old 01-20-2011, 06:15 PM   #23
e30_kid89
The Afro-stig
e30_kid89's Avatar
MS1 blows, just do yourself a favor and get the PNP and be done with it, not needing to look back.
