Old 01-11-2011, 02:53 AM   #1
El Gato Liso
El Gato Liso's Avatar
its 2011...what do you have planned for your e30??
"Hey guyzzz
I just thought we could all share what we are going to do or what we would like to do in the not too distant future (ie. 2011)
It would be cool say then at the end of the year we can bring back up this thread again and see what rly got done/what didn't/who sold their E30/who r3v'd their E30.
I think we could use this format like so:
-Year/model
-Color
-Mods/stuffs already done
-Things you wanna do to your E30
-How you plan to use those mods or what are you going to be doing with your e30 this yr. (track, auto-x, mall rat, crusin etc)"
and to add a twist, post a pic of your e30 at the moment!
I will start
-1990 325i
-Diamond Schwartz Metallic
-M50TU Swap, Slammed....on sportmax or supersport springs, audio system, Small diameter Dyno steering wheel on butchered/modified momo custom hub with screw pattern dyno to momo hub adapter, custom down pipes to cat, new PVC Valeo Clutch, shaved and lightened M20 flywheel
-S50 Cams/Tune, New shocks and anything suspension related, Z3 1.9 shifter, iS lip, swap out the 3.73 Open diff for newly acquired 3.73 LSD (thx to the original maker of this thread), sell e30 and get e46
-i plan on just autocrossing and croozing really. probaly get on a big time track ie. mosport.
a lession for those M50'ers with G260 trannys...its a bitch to pull the oil pan off as the ransmission HAS to come off. ...oil pan is on now. just putting everything back together oooh i cant wait to get behind the e30 wheel again
R.I.P. E30
Old 01-11-2011, 10:44 AM   #2
InfiniteDice
14 Years with the E30
InfiniteDice's Avatar
1987 325i
Black
Stock M20, running 19lb injectors on Miller MAF gen3 conversion. 7000rpm.
K&N cold air intake with shield.
-200+lbs (AC delete, ABS delete, Tar Delete, Carpet Delete.
B&G Springs, M3 CABs, Eccentric TABs, Solid Rear Carrier mounts, Boge Turbo Gas.
15" BBS RM 8" wide polished, w/ Toyo TR1
Euro smiley's with working city lights, smoked taillights, 20% tint on sides and back.
2.73 LSD (my attempt at saving some gas, I have a 3.73 LSD backup)
535i green engine mounts, modified to fit. (raises engine about 3/4 of an inch I never worry about cracking my pan.
z3 2.5 short shift conversion, removed balancer from drive shaft.
If I think of anything else I'll add it later.
Old 01-11-2011, 11:08 AM   #3
BigD
the misanthropist
BigD's Avatar
For me, it's easier to list what isn't being done - other than small modifications, the dash and sheet metal will be unchanged. Otherwise, everything is being redone. E36 M3 front, MCoupe rear, S52 getting built for serious power, new crazy fuel system, new brake lines (even hard lines) with a prop valve etc etc
Old 01-11-2011, 01:07 PM   #4
13blackknight
13blackknight's Avatar
M3
1988 M3
Dimondswartz
Cruzin,track etc....
get it on the road this year still puting it back together and missing driver side mirror.
what's done:
GC/Koni coilover
Ireland racing sw/bars,bushings
Subframe reinforced
tranny/diff and motor /freshened up, new clutch,water pump.
samco coolant hose kit.
custom SS exhaust and evo2 header
french "yellow" smiley's
New factory antenna
planned for this winter:
E3, undertray and splitter
E3 rear adj wing.
all remaining hoses in the engine bay to be replaced
17" alpina rims
Stereo
future plan: 2011 & 2012
Haltech and Cf intake
13blackknight is offline   Reply With Quote
Old 01-11-2011, 01:08 PM   #5
Was thinking to maybe put mine up for sale in the spring. I need something faster.
Old 01-11-2011, 01:12 PM   #6
That's what you'll be saying 2 weeks after you buy an E46
-1990 E30 325i
-Diamond Schwartz
-mods: Innovate LC-1, 19lb injectors, M30 AFM, K&N air filter, Ground Control Coilovers 500f/700r, TMS SS lines, MarkD 91 octane chip
-To do list: tune-up, patch up a couple cancer spots, change timing belt and water pump, fabricate skid plate, depending on funds headers and exhaust
-I will be hitting as many auto-x events as I can this year and hopefully at least one lapping day, maybe at the new Grand Ben track, cruises, and road trips
-1984 E30 325e
-Bronzit
-mods: boost
-to do list: sort out issues with MS install, change the brakes, install lowering springs, replace the hood (funny story)
- I want to get the car driveable and tuned, safetied and just drive it into the ground or until the motor explodes from boost
no pics of cars because both are stuffed into a shed down the road from my house.
Winter 2011 may also carry an interesting build depending on money and if we get a shop built at my house this summer
Old 01-11-2011, 01:32 PM   #7
BigD
the misanthropist
BigD's Avatar
was thinking to maybe put mine up for sale in the spring. I need something faster.
wunt to tarde me for skyline?
Old 01-11-2011, 01:36 PM   #8
BigD
the misanthropist
BigD's Avatar
If you haven't bought these yet, I've got 550f/750r springs I need to sell. That way you just need the adjusters.
Old 01-11-2011, 01:38 PM   #9
LOL! Only if its got purple tires and a pink unicorn sticker on the side!
Old 01-11-2011, 01:50 PM   #10
E30M42cab
Parts Hoarding Specialist
E30M42cab's Avatar
I'm not going to go over what has been done to my cars because most of you have seen the cars before, so I'll just say what I've got planned for the spring. Most of it is just aesthetic.
For the 1991 318is:
Alpina rep green tach stripe
Euro Analog clock
Euro Grills
Euro Plate filler
E28 M-tech 1 rear spoiler
H&R Race spring
(All ball joints and bushings were done in the fall, as well as a Suspension Techniques front sway bar.)
For the 1991 318ic:
E90 Drop hats (and remove the spring pads for a little extra low)
German 6 button clock
Vinyl wrap the hood to cover all the stone chips and the peeling clearcoat
Kamei x1 stripe set
Kamei Centra 15 x 7 et26 rims with 10mm front and 15mm rear spacers... hopefully
AC Schnitzer rear spoiler, if it will look good
(4.27LSD was put in early in the fall)
Mom's 1989 325i
Tach clock (got it for free!!)... just have to figure out if it will work for late model cars
Dad's 1992 318ic
Steal Rob's AC Schnitzer rims and Sam's tires from his TSW's!
That is all.
Grow up and move on.
Old 01-11-2011, 02:26 PM   #11
Those were in my current mods list. I did all the suspension last year. Thanks though.
Old 01-11-2011, 02:29 PM   #12
BigD
the misanthropist
BigD's Avatar
Gotcha. Yeah I realized that later when I noticed the "to do", I thought the mods were "to do mods".
Old 01-11-2011, 05:33 PM   #13
DR.ZED
85 325e with fresh i engine swap.
H&R race springs
Rear Bilstein sports.
Possibly sell my 15" BBS RMs for 16" somethings.
Cam G.
85 325e M5
07 Honda Shadow Spirit 750
Old 01-11-2011, 05:56 PM   #14
e30_kid89
The Afro-stig
e30_kid89's Avatar
Bout damn time somebody made this thread...I was just about to.
Got nothing to share this year
Old 01-11-2011, 06:11 PM   #15
Chris de la Cruz
sex, drifting & punk rock
Make sure I stop hitting shit? LOL
www.CSCS.ca
