Old 12-29-2010, 10:31 AM   #1
328IScreamer
328IScreamer's Avatar
How hard is 11 to 18 button obc conv
Like title states. I'm thinking of tackling this but am curious how hard it actually is. For ppl that have done it how long did it take you? Any good DIY write ups?
Old 12-29-2010, 10:47 AM   #2
http://forums.bimmerforums.com/forum...&highlight=obc
Seems like too much work.
Old 12-29-2010, 11:40 AM   #3
blk325i
blk325i's Avatar
it's not that much work i dont think it took more than an hour when i did it maybe an hour and a half, and if you google it you can find a bunch of good diy's
blk325i is offline   Reply With Quote
Old 12-29-2010, 11:45 AM   #4
blk325i
blk325i's Avatar
I also didn't bother with the stalk or the code feature, so i didn't have to tear open my glovebox or the area around my steering wheel.
just had to pull out the cluster, obc and sunglass holder
Old 12-29-2010, 10:21 PM   #5
doogee
doogee's Avatar
The instructions on bimmerforums seem scary but it really isn't a big deal.
For the most part you're just matching up wires by color and I think there's only 3 or 4 wires you route to the cluster.
The turnstalk and code feature are really easy too. Only two wires.
Dakar M3 Track Build Thread
Old 12-30-2010, 12:19 AM   #6
tg07lq
if you have an 11 button you dont need to even cut off the one harness. just splice into it, its reall simple, done a couple now, doing it only takes an hour or so. much harder if you go from a 7 button to 18
4cyl autotragic woes...
tg07lq is offline   Reply With Quote
Old 01-07-2011, 10:07 PM   #7
black bnr32
black bnr32's Avatar
http://www.pelicanparts.com/bmw/tech...BD_Convert.htm
can anybody verify the directions of the poster named 'mon'?
black bnr32 is offline   Reply With Quote
Old 01-08-2011, 04:02 AM   #8
This doesn't sound right. I think if you have a 11 button you gotta add one connector. If you have a 7 button, you have to rewire one connector, and add another.
Old 01-08-2011, 09:50 PM   #9
tg07lq
the last one i did is fully functional, i didnt do anything but splice into the one connector. that said i think you add the connector to the one side opposite, id have to check my car and get back on it
Old 01-10-2011, 05:58 PM   #10
Axxe
Over 9 F**KING THOUSAND!!
Axxe's Avatar
Piece of cake. Don't forget the turn signal stalk too, it's a nice touch. Some of the instructions on BF.c had me laughing, the one guy just twisted wires together and heatshrinked them, no permanent mechanical connection. You have to either crimp it or solder it, I prefer crimp, it's faster and you don't have to use a torch around the rest of the interior.
Old 01-11-2011, 05:26 PM   #11
328IScreamer
what is the difference with the turn stalk??
Old 01-13-2011, 12:56 PM   #12
Axxe
Axxe's Avatar
You push the stalk "in" (towards steering column) and it clicks, and cycles through all the displays on the 18 button OBC.
