Thread Tools Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
Old 12-28-2010, 05:56 AM   #16
Gtfour
Gtfour's Avatar
My new daily driver with the shop trailer, need to admit the F150 is a bit gutless:roll:
It,s a very simple design made of angle bars, i just start to drill some hole, save some grams:facepalm:
May help somebody
Gtfour is offline   Reply With Quote
Old 12-28-2010, 05:58 AM   #17
Gtfour
Gtfour's Avatar
I put the car on the scale 2 minutes ago and here are the result:
(CAR IS FULL OF GAS, +-60liters, NO DRIVER)
LF 747 RF 767
LR 672 RR 672
Total 2858lbs
Cross 1439 50.3%
Those numbers are just the weight of the car, no corner weight balancing been done right now to the car, only aligned the car with camber, caster & toe and adjust the height to approximately 13.5'' front & 13'' rear.
So aproximately 2800 lbs without driver and half tank of gas.
Went to Le Circuit Mont Tremblant friday, car feels good but i was so slow:facepalm: A lot of rattle/noise coming from the rear end.
A rear wheel bearing was completely destroy after the second session and the bracket of the Supersprint race muffler on driver side broke, exhaust was loose and shaking...
Need to fix this before next day at Calabogie Motorsport Park.
Just had a Blind Apex lap timer
Old 12-28-2010, 10:09 AM   #18
twboy1999
thats hardcore
1997 honda accord
twboy1999 is offline   Reply With Quote
Old 12-28-2010, 12:08 PM   #19
3x Beemer
wow I've been waiting for this thread since you joined and said you'd do a build thread. you're exterior mods alone are what most guys only dream of. looks great. how is the new motor? seem any faster with less km on it?
17 Audi A4 S Line
03 AW on LSB M3 coupe, BMW motorsport 4.10 Diff, AA Exhaust, OEM CSL rims, Aero Res, TMS subframe, powerflex bshgs, Macht Schnell, Vorsteiner diffuser, TMS steel lines etc.. Sold
Complete Comp Pkg Upgrade
2012 Honda CRV winterbeater
3x Beemer is offline   Reply With Quote
Old 12-28-2010, 12:56 PM   #20
This is quite the track build. Awesome stuff.
Looking forward to videos of this thing on the track!
Old 12-28-2010, 03:11 PM   #21
EMPOWERD
EMPOWERD's Avatar
Nicely done! shaved 600lbs from stock... amazing.
My YouTube video
-- RANDY SPARRE --
Old 12-28-2010, 11:27 PM   #22
dble Trouble
TAKE IT TO THE TRACK
dble Trouble's Avatar
Very impressed with the quality of these mods, good work, nice show, and by the way, your english is more than fine!
Old 12-29-2010, 12:42 AM   #23
Yamahammer
Warlock of the century
Yamahammer's Avatar
good lord ! Amazing work
Old 12-29-2010, 01:54 AM   #24
Gtfour
Gtfour's Avatar
Thanks everyone for the kind words
If the thread seems weird sometimes, it's becaue I did a copy/paste of my build-up thread from m3forum.net. I just took the pictures and sometimes some sentences seems to comes from nowhere...
I am installing the new engine right now, so i won't know if it makes a difference until april.
Here is the main reason why I swap a new engine into the car:
I was at Calabogie on July 14 and during 3rd session of the morning, at the end of rocky road entering Mulligans corner, i downshift from 5th gear to 3rd gear. When i blip the throttle from 4th to 3rd while I release the clutch pedal, revs went up to 7000rpm and suddenly the engine feel rev happy like someone swap a lightweight flywheel in a faction of a second. At that point, i knew something wrong was happening
I got back to the paddock at 3k rpm to make sure I don't break anything else. The car was running OK but a loud rattle noise was coming from the engine bay. Here is what I discovered in the paddock:
The harmonic balancer melt/split in 2 pieces
I installed another balancer 2 days later and there was a noise coming from the crank and the accessorie belt was shaking... I was sure at this point that is blew the engine and bent the crank. I tought the rods bearings were gone from the noise i heard. Also, this is what my magnetic oil drain plug looks like:
I stopped the 2010 season right there, I was so frustated. I finished building the car in june and a month later, car was broke and itaor failure.
I didn't touch the car until november, I bought another engine/tranny between that time since my car has 175000km on it. I removed the damage engine from the car and removed the oil pan. To my surprise, all crank and rods bearings looks fine. The only thing i found was a loosse guide chain tensionner. The noise was coming from the oil pump chain guide. The chain also got in contact with the pump housing. And the closest bearing to the flywheel show sign of wear, like if the crankshaft assembly had shift to the front for seconds, axial play.
Old 12-29-2010, 02:05 AM   #25
Gtfour
Gtfour's Avatar
My best friend came at the shop today and worked on the front bumper aerodynamism while I was installing the wring harness back in place. He installed Bimmerworld dive planes and create a kind of lip (with a Subaru oem lip) under the mouth to avoid the air to go between the splitter and bumper.
and here is a shot of the custom 3" single pipe muffler, 2 turn-down pipes I started to do couple of weeks ago
Old 12-29-2010, 02:13 AM   #26
Yikes! Dampeners on these high revving 6s seem to becoming a regular maintenance item... I've seen two others have similar threads on Bimmerforums regarding these. The E46 M3s that used to/still run in Grand Am Cup/Conti Challenge replace these dampeners every few races. But then again, those guys drive the hell out of those cars!
Are you planning to maybe rebuild the old engine with some fancy parts? Or just part it out?
Old 12-29-2010, 02:33 AM   #27
Gtfour
Gtfour's Avatar
Just a teaser of what i plan to do this winter:
-Moton Clubsport dampers, spring rate 700front 800rear (i will install them in the end of January)
-Custom headers with 2.75" pipe from collectors
-Custom carbon fiber dashboard (because my car is anorexic)
-Maybe a rear diffuser
-Front windows for rainy days (lexan)
-And a complete rollcage (we ordered a tube bender and a tube notcher at VAG Motrsport but didn't receive it yet)
I would really like to stay at 2800lbs with a full rollcage
Old 12-29-2010, 02:49 AM   #28
Gtfour
Gtfour's Avatar
Yes, harmonic dampers are maintenance item, like the Vanos hose that goes to the accumulator, they crack with vibration.
I am not 100% sure but i think that the 10lbs lightweight flywhhel doesn't help the balancer lifetime... An inline 6 get a long crankshaft and the S54 pistons travel at a very high speed, vibration on the crankshaft is something to consider when modifiyng those engine.
Another guy i know blew his engine, the balancer melt/split in 2 pieces like me but the crank seals were dripping and it just seems worst than mine.
I think my engine is still good, don't want to split/part-out a functionnal engine. I will remove the crankshaft and see/measure if it is still straight.
I am not sure right now what route I will go in the future: boost or NA?
It would be so simple to put a supercharger level 2 kit with stock internal. And when it break, S54 go fo 3000$ now so... And you can run on pump gas and get a lots of power.
Before, I was dreaming of CSL airbox, Schricks cams, even stroker, but it cost $$$$ vs gains.
The only thing that affraid me with boost is heat.
Anyway, I am far from adding power to the ///M right now, not before a year or two!
Old 12-29-2010, 02:52 AM   #29
Gtfour
Gtfour's Avatar
I will also fabricate a duct to throw cold air directly on the harmonic damper to help lifetime.
3 things seems to destroy them:
-heat
-vibration
-and how long it been installed on the car
It was a 3/3 for me...
Old 12-29-2010, 03:17 AM   #30
-heat
-vibration
Excellent idea! Even the PTG E36s of the late 90s had a dampener duct in the front bumper. Shows how even those Euro S50s were stressed with the higher RPMs they ran.
