Old 12-21-2010, 03:30 PM   #1
DimSumE90
BMW Scanner Car Diagnostic Tool (Version 1.4.0)
So it looks like those guys at dealextreme.com
Finally have something worth us looking at!
Good for older generation cars, no good for the new stuff.
The new cars you'll probably need BT tool.
Would be good use for you maxbimmer guys.
I drive an E90 so I'm looking for the version 2.1.0.... But the Bavarian Technic is probably the best choice.
www.littlebimmer.com
DimSumE90 is offline   Reply With Quote
Old 12-21-2010, 03:45 PM   #2
SiR
Vtec just kicked in
you dont need a "bmw" scanner though $48 is cheap..but you still need a laptop.
other scanners you can buy at ct and princess auto dont require a laptop.
-||Old Crayons||-
Old 12-21-2010, 07:29 PM   #3
radi0activem
You can a lot more than just scan code with BMW Scanner.
Anyone know if you can enable the BC button on an E46 with BMW Scanner?
This is the main thing that I would want to do but I can think of a lot more to enable/disable too.
Brian
2003 530i
radi0activem is offline   Reply With Quote
Old 12-21-2010, 11:46 PM   #4
DimSumE90
+1 the bmw scanner can clear codes too!
Thats why I said it's good use for those E46 peoples who want to clear the engine and airbag codes.
Old 12-22-2010, 03:39 AM   #5
SiR
Vtec just kicked in
if it can clear airbag code then that is definitely useful over a standard obd code reader.
-||Old Crayons||-
Old 12-22-2010, 10:31 AM   #6
BimmerGuys
BimmerGuys's Avatar
The problem is the you need the right laptop to operate the pasoft 1.4.0. There are some driver issue with this software.
BimmerGuys is offline   Reply With Quote
Old 12-25-2010, 05:22 AM   #7
motion
Hell Spawn
engine code and airbag code are two different scanners.
motion is offline   Reply With Quote
Old 01-11-2011, 01:32 AM   #8
okicu
I bought this scanner around Christmas time and it doesn't work on my e60. so is my only alternative to get the 2.01?
okicu is offline   Reply With Quote
Old 02-21-2011, 09:20 PM   #9
radi0activem
I ordered this and then cancelled the order 6 weeks later because it hadn't been filled.
Gotta find another source for this....
Brian
2003 530i
