Old 01-20-2011, 12:24 AM   #16
talltorontoguy
Go Topless
talltorontoguy's Avatar
Rod, I'll have SSK' in about a month again, I'll let u know when they are in and u can try it out in my car
Sure sounds good
Join BMW Club of Canada! Click HERE
Best Engine, Bimmercruise '10 / 2nd - e30 Wild, Bimmercruise '10 / 1st - Best Cabrio, Trillium @ Tedfest '11 / 1st - e30 Wild, Bimmercruise '11 / 1st - e30 Wild, Bimmercruise '12 www.vertnation.com
talltorontoguy is offline   Reply With Quote
Old 02-03-2011, 11:30 PM   #17
talltorontoguy
Go Topless
bump... lookin mostly for turbo bits now, megasquirt, racing seats. Other interesting stuff...
Rudy I owe you a call...
Old 02-04-2011, 01:55 AM   #18
richie_s999
Got ssk's in pm'd u contact info
Old 03-03-2011, 05:03 PM   #19
talltorontoguy
Go Topless
bump
Old 03-03-2011, 05:07 PM   #20
talltorontoguy
Go Topless
Z3 (I6) Rear 5 lug rear trailing arms with brakes - HAVE
Z3/E30/318ti Urethane RTAB - NEED
E36 M3 spindles - HAVE
E36 M3 front brakes - HAVE
E30 325 urethane engine mounts - NEED
16" pusher fan - HAVE
e28 3.25 lsd - NEED
Megasquirt II - NEED
VDO gauges with sensors - NEED
M30 ARP head studs - NEED
M30 Upper Gasket kit (new) - NEED
M30 Lower Gasket kit (new) - NEED
M30 Timing chain (new) - NEED
M30 Timing chain tensioners (new) - NEED
M30 Turbo manifold - NEED
M30 Turbo (TCD / HX35 etc) - NEED
M30 Turbo downpipe and dump tube - NEED
Tial Wastegate 38mm - NEED
Old 03-03-2011, 05:43 PM   #21
BigD
the misanthropist
BigD's Avatar
Did you get the MCoupe trailing arms? If they're the regular i6 Z3 arms, this is what your wheels will look like:
See item 4 under Trailing Arms and Hubs:
http://extradrei.com/5lug.html
Old 03-03-2011, 05:54 PM   #22
talltorontoguy
Go Topless
That is easily remedied by the installation of a wide body kit. .
I'm just using the i6 hubs, on the existing E30 trailing arms. (I should have modified my list.) That way I get the bigger bearing and don't have to swap arms. It's only a problem when you use the wider arms and all.
With this set up I can use E36 offset wheels with standard bodywork, or lower offset wheels with body modifications.
TTG
Old 03-03-2011, 06:07 PM   #23
BigD
the misanthropist
BigD's Avatar
I guess, but you'll need a serious widebody just to run normal rims. You could just use the hubs and brakes as he suggests on the site. You can still get the widebody but you'll also be able to fit nice looking meat.
Just my 0 cents.
Old 03-03-2011, 11:30 PM   #24
talltorontoguy
Go Topless
Just my 0 cents.
Yep - that's exactly the plan ... run just the hubs (i6 / i4 are same except for bearing) and brakes with standard bodywork and e36 wheels.
Old 03-04-2011, 01:38 AM   #25
BigD
the misanthropist
BigD's Avatar
Ah ok, gotcha! Ok sorry I'll stop polluting your thread
