Old 12-14-2010, 02:47 PM   #1
talltorontoguy
Go Topless
talltorontoguy's Avatar
New Build - need parts...
Building project X. This one will have a roof.
Looking for...
Z3 (I6) Rear 5 lug rear trailing arms with brakes
Z3/E30/318ti Urethane RTAB
E36 M3 spindles
E36 M3 front brakes
E30 325 urethane engine mounts
Z3 SSK (or comparable)
16" pusher fan
e28 3.25 lsd
Megasquirt II
VDO gauges with sensors
M30 ARP head studs
M30 Upper Gasket kit (new)
M30 Lower Gasket kit (new)
M30 Timing chain (new)
M30 Timing chain tensioners (new)
M30 Turbo manifold
M30 Turbo (TCD / HX35 etc)
M30 Turbo downpipe and dump tube
Tial Wastegate 38mm
PM...
Join BMW Club of Canada! Click HERE
Best Engine, Bimmercruise '10 / 2nd - e30 Wild, Bimmercruise '10 / 1st - Best Cabrio, Trillium @ Tedfest '11 / 1st - e30 Wild, Bimmercruise '11 / 1st - e30 Wild, Bimmercruise '12 www.vertnation.com
talltorontoguy is offline   Reply With Quote
Old 12-14-2010, 08:07 PM   #2
E30M42cab
Parts Hoarding Specialist
E30M42cab's Avatar
Tracking a vert just not doing it for you, Rod? What did you pick up?
Grow up and move on.
Old 12-15-2010, 12:48 AM   #3
hhehehehe, I like where this project is going!
Old 12-15-2010, 02:19 AM   #4
talltorontoguy
Go Topless
The vert is actually surprisingly good on the track... I'm not yet at the level to bring it anywhere near it's limits but Bruno gave it a good run at last driving school and got closer (still not at its limit) and was shocked at how stiff the thing is and how well it handled. The turbo m30 doesn't hurt coming out of the corners either.
However, if I'm going to do it, I want to do it right and safely. (that's my excuse for this build anyway). The vert will still be a summer cruising speed demon.
Project X (If I can make it happen) won't be streetable at all. That is all I'm sayin' for the moment.
Me too!
Old 12-15-2010, 01:34 PM   #5
E30M42cab
E30M42cab's Avatar
Well, I know you were complaining about understeer on the track at the Trillium Club show and shine, but I wasn't sure if you had put increased camber mounts in yet to try to correct it. The difference I've found between a vert chassis and a coupe chassis is night and day when it comes to being nimble... overall handling isn't far off on the street, but the verts are just not happy being twisted around.
Ever thought about doing an S38?
Old 12-15-2010, 01:53 PM   #6
talltorontoguy
Go Topless
Yes I did have bad understeer in the vert at TMP. After that (and after the trillium show) I installed front camber plates, drop hats, and an IX rear sway with new bushings before going to Mosport DDT, where I also played with tire pressures front and rear. Was night and day. My car has solid engine and tranny mounts so the driveline effectively acts like an X brace. Strut bar helps up front. The factory hardtop also helps stiffen. Is it as stiff as a non-vert with same setup? Maybe not... but it was plenty stiff. I may add a butt strut and solid subframe / RTAB bushings to finish it off.
I've thought about the S38 for this new build, but the purchase/rebuild/maintenance costs outweigh the benefits in my opinion for what I'm trying to do with the budget I have in mind.
Old 12-29-2010, 01:42 PM   #7
talltorontoguy
Go Topless
bump... still looking for many parts
Old 12-29-2010, 02:32 PM   #8
^ I'll PM you in a bit, too much to text, and I'm just catching up on a few other PMs, box was full again this morning!
Old 01-14-2011, 02:32 PM   #9
talltorontoguy
Go Topless
Bump it up... still looking for many parts... mostly turbo bits and megasquirt.
Old 01-15-2011, 03:11 PM   #10
JdmEuroNorth
JdmEuroNorth's Avatar
http://www.maxbimmer.com/forums/showthread.php?t=125534
LOOKING FOR: M42 rad or e36 coolant reservoir, flywheel and clutch for m50 and inline fuel pump!
JdmEuroNorth is offline   Reply With Quote
Old 01-18-2011, 01:47 AM   #11
talltorontoguy
Go Topless
thanks for the bump JDMnorth. Glad you're here keeping us in line.
Old 01-18-2011, 07:44 PM   #12
JdmEuroNorth
haha yeah yeah.
Old 01-19-2011, 10:49 AM   #13
Still want the shocks?
Old 01-19-2011, 12:16 PM   #14
richie_s999
Rod, I'll have SSK' in about a month again, I'll let u know when they are in and u can try it out in my car
Old 01-20-2011, 12:23 AM   #15
talltorontoguy
Go Topless
Yes, just got back from NYC. Will be in touch...
