Originally Posted by dcramer
It's ordered and on it's way. My sunroof is apart and their instructions are only good for older cars. Mine is a 98 and the inside part does not slide back as per their instructions, I took the cassette out and still struggled with it. Now I know how it comes apart and could do it in the car. You need to put it in the raised position and undo the 17 mm nuts from the back of the raised sunroof. You can get to the small screws in the front when it is raised as well. Then there are pins on the pieces that the screws come out of that have to be separated . I'll take a picture later.
Ok added pictures you can see in the first one there is a hole where the screw goes and then forward of that there is a pin. If you look at the 3rd picture You can see where the pin fits and the adjustment for height where the screw goes.
The 2nd picture shows the shims for the back of the sunroof for height adjustment. Added that for completeness. Probably worth marking so you don't have to eff with it, since it won't be easy to adjust.
