Old 12-11-2010, 06:07 PM   #1
Ceeker
e30 technical question
heating issue: changed the thermostat to 70C had an 80 before. Changed the fan coupling; changed the heater core and tap; changed the update inline valve on the heater hose in the engine bay. Bled the system thoroughly.
WHY AM I STILL GETTING LUKE WARM AIR!!!! ARG!!!!???
1 90 325is white - keepin
1 87 325i vert -red - keepin
KEEPER 88 5sp Vert 2016
Old 12-11-2010, 06:13 PM   #2
HavocSteve
Same thing happened with my E30. I thought it might have been a dying heater core.
Old 12-11-2010, 06:28 PM   #3
Ceeker
Steve, I had all these spare parts so I am lucky but now I have spent probably 8 hours trying to figure this shit out. I don't think it is the rad because it would otherwise be over heating. I suspect it could be the heater dial/switch in the cabin. May not be sending the proper signal to the heater tap to open. I mean the system isn't complicated.
Old 12-14-2010, 01:45 AM   #4
noid
noid's Avatar
Theres a recall for the cooling system, where they reroute the flow of coolant (in the process give you a new thermostat and some other stuff). You might want to check into if its been done for your e30, if it hasnt its worth getting shit changed for free, and potentially fixing your problem. I remember i had it done on my 87 325i when i had it.
Old 12-14-2010, 02:10 AM   #5
InfiniteDice
14 Years with the E30
InfiniteDice's Avatar
Probably the heat mix dial linkage or:
Get it hot, put the heat on full and high, and open the hood.
Flex the small coolant line that goes from the back of the engine to the firewall. At the same time flex the top and return rad hoses. Sometimes air gets trapped in the heater core and you need to flex it that way. Try bleeding at the thermostat housing, repeat.
If it doesn't improve after 2 or 3 repeats it has to be the heat mix dial control.
It is possible a previous owner used tap water and the heater core is all loaded with calcium, but that's the least likely thing I can think of.
Old 12-14-2010, 02:24 AM   #6
What cars were covered under that?
Old 12-14-2010, 03:46 AM   #7
noid
noid's Avatar
enjoy:
http://wwwapps.tc.gc.ca/saf-sec-sur/...f=SearchResult
Old 12-14-2010, 11:11 AM   #8
NOTORIOUS VR
NOTORIOUS VR's Avatar
Probably the heater core... if you have no air in your system and a good coolant flow.
If you want to try and save your heater core, you can disconnect it, flush it with water, and then fill it with CLR, let it sit over night and then flush again, connect fill/bleed your cooling system and see how it goes. If that doesn't work, new heater core time.
Old 12-14-2010, 11:43 AM   #9
Ceeker
thanks for all your input; but in my original post it does indicate I changed everything including the heater valve (SIB) in the engine bay which was a recall due to heater cores exploding causes the drivers legs to get burned. they typically get clogged when coolant isn't flushed regularly.
You can also check for updates on the heater tap as well.
parts changed:
- thermostat -71 degree Celsius
- fan coupling
- heater core
- heater tap
- heater dial
- heater valve-engine bay
So...I suspect it being the thermostat as when I sit idling the temp gauge starts climbing but as I accelerate the temp gauge drops and stays at 1/4. which I believe isn't high enough to give adequate heat to the compartment. I believe I am going to need a 80 degree one to fix this problem.
most likely oem as aftermarket sometimes does funny things with cars. I also read in another site that omitting the heater valve in the engine bay eliminates the restriction and allows better flow to the core; once done it was noted that sufficient heat returned into the cabin.
Old 12-14-2010, 01:22 PM   #10
Any chance you got the input / output lines reversed on the core?
I would think a higher temp thermostat would be in order, 70*C is too low IMO. For rising temps at idle, that sounds like a fan clutch. Even when they appear ok, I've never had a E30 with rising temps that a new fan clutch didn't fix. They're fairly cheap new at autopartsway.ca where I got the one in my E30 I have now.
Old 12-14-2010, 03:57 PM   #11
Ceeker
Originally Posted by everlast View Post
Any chance you got the input / output lines reversed on the core? aluminum pipe at bottom and black plastic up top. :-)
it's possible, anything is possible, but it's highly unlikely since I've been doing this for a bit too long now..lol
Fan clutch is new. rising temp with a fan clutch is normal to operating temp. But mine is below operating temp so it will climb while idling. but because the thermostat is perhaps staying open it isn't allowing the motor to get to operating temp. so the clutch disengages. have to remember everything is connected and not isolated. so I used the process of elimination to narrow things down.
Old 12-14-2010, 03:57 PM   #12
... I'm confused as to why you put in a 70*C thermostat?
Old 12-14-2010, 04:14 PM   #13
Ceeker
that was the only thing available at the time "new" which was oem. I was told it was 80. and upon pickup turned out to be 71 . I didn't want aftermarket. since it was 15.00 I figured I'd try my hands at the lack of heat problem. Thermostat was the first thing changed. So I went from there. now I'm going back there. There can't be any other explanation for my problem as I changed everything related.
Old 12-14-2010, 05:08 PM   #14
E30M42cab
Parts Hoarding Specialist
E30M42cab's Avatar
put in an 80 and be done with it. Your old one was probably stuck open, so put an 80 back in and you'll be fine.
Grow up and move on.
Old 12-14-2010, 07:29 PM   #15
DR.ZED
+1 Failing heater core. Same exact thing happened to me.
Cam G.
85 325e M5
07 Honda Shadow Spirit 750
