Old 12-07-2010, 10:02 PM   #1
BiggyAlex905
05 x3. 2.5
Hope some one can help.
No heat on idle in the morning till I start to drive it, then it's fine.
BiggyAlex905 is offline   Reply With Quote
Old 12-08-2010, 11:00 AM   #2
Low coolant? Had that happen on my Range Rover.
Old 12-08-2010, 11:35 AM   #3
MiroE36
MiroE36's Avatar
could also be thermostat
Old 12-08-2010, 02:31 PM   #4
King Luis
The King.
King Luis's Avatar
i'm guessing thermostat....but it's probably easier to check your coolant level first.
Mods: TBD.
Sold:2004 Silver Gray M3
Gone:1990 Brilliantrot 325is
Old 12-08-2010, 02:45 PM   #5
NOTORIOUS VR
NOTORIOUS VR's Avatar
low coolant/air in the system
otherwise I would say water pump is on it's way out.
the thermostat has nothing to do with the heat exchanger in the car
Old 12-08-2010, 07:48 PM   #6
notme
Thermostat
notme is offline   Reply With Quote
Old 12-09-2010, 06:55 PM   #7
Dr. Flyview
"Mint"
Dr. Flyview's Avatar
How can you say that? If the thermostat is stuck open (coolant constantly flowing through the rad), then the car takes a lot longer to warm up, and possibly not warm up to where it's supposed to at all. I had that happen on my benz.
I thought this thread was a joke. No heat in the mornings aka when he first starts the car, and at idle. Well duh you have to drive the car for 10-15 minutes before you get heat.
1998 BMW 328is - summer
1993 BMW 525i - sold
1994 BMW 325i - sold
1992 BMW 325i - gone
sold
Old 12-09-2010, 07:25 PM   #8
abc12
i was thinking the exact same thing as well, but didn't bother post regarding that. since his question is no heat in the morning, and he doesn't mention whether or not if it's a cold start. he also mentions it's fine once driven as he goes. to me sounds like his car is perfectly fine, but he's gotta be a bit more specific...
abc12 is offline   Reply With Quote
Old 12-09-2010, 11:34 PM   #9
NOTORIOUS VR
Because using a little judgement/logic I came to the conclusion that no one expects heat when the car is stone cold, plus he says he gets heat when he starts MOVING.
all you people saying is the thermostat aren't making any sense. Let me repeat. The OP says he GETS heat when he starts moving, but none when he is idle.
How the heck can that be the thermostat? Besides, the thermostat will never block the heater core, it only blocks flow to the rad.
It's either low on fluid/air in the system, or the water pump.
