Old 11-29-2010, 09:03 PM   #1
Nick_V
Nick_V's Avatar
2 Questions about 3M trim tape
1. Has anyone used it? I'm talking about the two sided tape with foam in between. The car in question has had bodywork done and I'm having a helluva time getting the door moldings to fit properly with the stock clips. Does it work well and how durable is it?
2. Where can I buy it?
Thanks,
-Nick
Old 11-29-2010, 09:58 PM   #2
325isdan
I used some but it was exposed to weather. Held all of two minutes after it got wet.
325isdan is offline   Reply With Quote
Old 11-29-2010, 10:54 PM   #3
simplycars
simplycars's Avatar
automotive 3m tape will work - try napa or carquest
simplycars is offline   Reply With Quote
Old 11-30-2010, 02:10 PM   #4
have you tried getting new clips and nipples?
Old 11-30-2010, 03:31 PM   #5
Nick_V
Nick_V's Avatar
^^I got DDM M3 moldings brand new. I heard mixed reviews about quality but thought what the Hell, they're cheap enough. One side fits perfectly but on the other side, as I mentioned, there has been bodywork done in the past. I can tell because you can see the cheese under the paint at the edges of the holes. The work done is far from a hack job, but it's kinda like taping drywall - you can't tell visually, but the presence of cheese raises the overall depth of the groove in which the clips sit just enough that they won't snap in like they're supposed to in some spots. Know what I mean?
I thought of possibly grinding down parts of the molding itself to allow it to come closer to the body, but it's probably just easier to use the tape. I found a few places that have it, but would still like to hear some reviews if anyone has experience with it
Old 11-30-2010, 03:48 PM   #6
BSL
BSL's Avatar
It works really nicely.
The key is getting the surface clean clean clean first.
Use 440 solvent, or isoproyl alcohol. Keep wiping the area with a clean rag, until no dirt shows on the rag.
Do both mating surfaces, make sure its dry
Whatever you stick on will never come off.
BSL is offline   Reply With Quote
Old 11-30-2010, 03:59 PM   #7
slemmer
Driving in the fast lane
slemmer's Avatar
You're referring to the 3M red automotive tape, right? Make sure you apply heat to activate the adhesive and rub it down good so it can bond the two surfaces.
'15 Ford F150 Lariat SCSB 4x4
'04 645cic
'00 740i Sport
Old 11-30-2010, 10:39 PM   #8
zarbat007
This should work:
http://www.autogeek.net/3m-auto-tape.html
zarbat007 is offline   Reply With Quote
Old 12-01-2010, 12:45 AM   #9
Nick_V
Nick_V's Avatar
Thanks guys, gonna pick some up and give it a shot.
Old 12-01-2010, 01:39 PM   #10
///Maluco
5erholic
///Maluco's Avatar
When you apply the tape (grey foam tape with red liner), make sure the ambient temperature is between 16-30 degrees C. That's the optimum temperature range for excellent tape adhesion.
Before applying tape to the moldings, apply some 3M primer (adhesion promoter) and let dry before you roll on the tape.
As mentioned, you need to also clean any dirt/grime/wax/grease from the mating panels on your car. Isoproyl alcohol works very well.
Remember, preperation is key.
..........................There will always be followers!
Bimmer Mag......................October 2010.....................Issue No. 93
///Maluco is offline   Reply With Quote
