**The following are pending sale**
- Crosman Pro77
- Crosman 1088
- Crosman T4
- Crosman T4 Tac.
- Beeman P17 w/ extended red dot
- Umarex Walther CPSport
- Crosman 2240
Selling my airgun collection to contribute towards the real-steel fund.
No licence required to acquire or use; cannot be converted to firearms; must be 18+ to buy.
All items in
Excellent to
Like New condition; aside from one item as clearly marked.
All prices are 'or best offer.'
Crosman Pro77 $45
- Model Number: PRO77CS
- Power Source: CO2 w/ blowback + empty mag slide lock
- Caliber .177 (4.5 mm)(Steel BB)
- 17-rd. semi-auto
- Velocity: Up to 350 fps
- Weight (oz): 21oz
- Length (in): 6.75in
- Barrel Material: Smooth Bore Steel
- Front Sight: Fixed Blade
- Rear Sight: Fixed Notch
- Includes 3 magazines
Umarex Walther CPSport $85
- Power Source: CO2
- Caliber: .177 (4.5 mm) (Lead Pellet)
- 8-rd. semi-auto.
- Velocity: Up to 400 fps
- Length (in): 7.1in
- Barrel Material: Rifled Steel
- Barrel Length: 3.3in
- Rear Sight: Windage adjustable
- Double-action only
- Includes 3 CO2 magazines
- Includes 3 pellet clips
- Includes tactical mount w/ Walther red dot
Crosman 1088 $25
- Model Number: 1088BG
- Power Source: CO2
- Caliber: .177 (4.5 mm) (Steel BB or Lead Pellet)
- 8-rd. semi-auto.
- Velocity: Up to 430 fps
- Weight (oz): 1.10lbs
- Length (in): 7.75in
Crosman T4 and
Crosman T4 Tactical $50 / $70
- Model Number: T4CS
- Power Source: CO2
- 8-rd. semi-auto.
- Velocity: Up to 430 fps pellet, Up to 450 fps BB
- Weight (oz): 1.32lbs
- Length (in): 8.63in
- Tactical ver. includes tactical mount and Crosman red dot
- Include 3 pellet clips (3 each)
Crosman Walther PPK/S (Matching Pair)(One has slide racking issues; not tested)
$55 for both
- Steel frame and slide
- Caliber: .177 (4.5 mm) (Steel BB)
- 15-rd. semi-auto.
- Velocity: Up to 295 fps
- Front Sight: Fixed blade
- Rear Sight: Fixed notch
Crosman 2240 $45
Average CTC of .37" @ 10m
- Crosman 2289 14.5" rifle barrel (Factory = 7.25")
- Crosman 2289 hammer spring
- Power Source: CO2
- Caliber: .22 (5.6 mm) (Lead Pellet)
- 1-rd. bolt-action single-shot
- Velocity: Up to 495 fps
- Weight (oz): 1.13lbs (factory)
- Length (in): 18.325in (11.125" factory)
- Rear Sight: Elevation and Windage adjustable
Beeman P17 $25 or with Crosman red dot [below] for
$40
- Power Source: Over-lever Pump
- Caliber: .17 (4.5 mm) (Lead Pellet)
- 1-rd. single-shot
- Velocity: Up to 410 fps
- Weight (oz): 1.7lbs
- Length (in): 9.5in
Beeman 1040 $145
- Power Source: Break-barrel Pump
- 1-rd. single-shot
- Includes Crosman red dot w/ extension tube
- Includes factory Crosman 4x32 rifle scope w/ mounting rings and caps
2 Crosman pistol holsters in mint condition
$10/ea.
