Old 11-21-2010, 04:30 PM   #1
canuckder
canuckder's Avatar
removing air vents,
so im wondering if its possible to remove the assembly that holds in the air vents above the radio. i have the air vents out, but cant figure out if i have to remove dash to get that assembly out?
thanks guys,
cal.
canuckder is offline   Reply With Quote
Old 11-21-2010, 04:35 PM   #2
Ceeker
If it is the surround you are talking about. I don't believe this comes out. if it does you'll most likely need to remove the entire dashboard from the car first. Unless you are going to start hacking away at it.
1 90 325is white - keepin
1 87 325i vert -red - keepin
KEEPER 88 5sp Vert 2016
Old 11-21-2010, 04:42 PM   #3
canuckder
canuckder's Avatar
well if it didnt come out easily, im planning on cutting out the center that divided the vents.
im trying to fit some gauges in there, i cut out some plexi glass and made some hangers already. i just didnt like the looks of the "flow dials" still there, gonna look at it some more.
Old 11-21-2010, 06:59 PM   #4
E36is
'OldSchool..'
E36is's Avatar
just my thoughts, but why not use the radio hole for your gauges and put your radio HU in the glove compartment?
Old 11-21-2010, 07:11 PM   #5
Ceeker
I agree to that! this way you don't destroy the dash and you already have space for the gauges. the radio you can stick anywhere. :-) Another spot I've seen gauges is in the cubby hole just above the ashtray. or just behind the park brake handle in the partition try
Old 11-21-2010, 07:56 PM   #6
BigD
the misanthropist
BigD's Avatar
The vent console is held into the ducts by clips. I'm not sure how to do it gracefully but I didn't intend to reuse mine so I just grabbed the center with some pliers and gave it a good yank.
Old 11-21-2010, 08:24 PM   #7
canuckder
canuckder's Avatar
glove compartment is spoken for, hiding some goodies away.
and thanks, i started to pry one end and kind of saw it starting to pull out. gonna go back at it tommorrow when i get some light
Old 11-21-2010, 09:10 PM   #8
canuckder
canuckder's Avatar
so i went to try it out,
as easy as you said it was. grabed the top with some vice grips, good tug and the hole assembly pulled out.
thanks guys,
Old 11-21-2010, 09:22 PM   #9
Ceeker
good to know..at least you have it in tact without damage. I suppose a cloth between the grips would help prevent damage while pulling it out.
Old 11-21-2010, 09:24 PM   #10
Ceeker
thanks guys,
you still got that M2 wheel?
Old 11-21-2010, 09:31 PM   #11
canuckder
canuckder's Avatar
i doo still have that wheel
Old 11-21-2010, 09:46 PM   #12
Ceeker
I have a 3-spoke in my vert, but the leather wore through and I need a newer wheel. Condition of the leather? nicks, scraps, wear? I would prefer one is good to great condition.
Old 11-21-2010, 11:15 PM   #13
canuckder
canuckder's Avatar
i sent you pictures before, has some scraps from storage on the one side. isnt pretty, but was told is fix-able.
Old 11-21-2010, 11:41 PM   #14
Ceeker
yeah, ok I now remember. how much did you want for it?
Old 11-21-2010, 11:47 PM   #15
canuckder
canuckder's Avatar
pm'd
