Golf Clubs: Callaway Diablo Edge Tour Fairway Woods 15 and 18 degree
Product Description
• Full hosels, less face progression, and smaller, more conventional headshapes compared to standard models
• Lowest, shallowest CG of any fairway wood Callaway has ever made for penetrating trajectories
• Ultra-thin VFT face creates hotter ball speeds across the entire face for longer, more consistent shots
• Callaway's highest MOI ever in a fairway wood dramatically improves accuracy
2 Callaway Fairway Woods DIABLO TOUR EDGE (nice classic look, with hosels)
15 degree (approx 43inches) and 18 degrees (approx 42.5inches)
Men's right hand, Stiff shaft, graphite
NEW Golf Pride Tour velvet standard grips logo down
NEW GOLFSMITH Reshaft done with Graphite Design AURA RED S flex, 68 grams, nice smooth lightweight shaft not overly stiff so no worries. Easy to get the ball up. Head has nice steely powerful feeling and pop to it.
Condition: Grip and Shaft new
NO HEADCOVERS
Head: sole has minor wear from turf no dings. face has more wear on the 18 degree and is noticeable, crowns are near perfect.
SHAFTS ARE BOTH PURED. This eliminates the inconsistencies in the shaft material to create a repeatable consistent bend. Most stock shafts wobble or don't bend the same way at impact due to manufacturing defects, hence unpure. These are PURED and will give you a 99% consistent bend if you swing in a close to similar way every time! So you can blame your swing not the club! MANY TOUR PROS ARE Puring shafts and you will see and feel the difference. Less likely to get those unexplainable flyers way right or way left due to dodgy shaft properties..
PURING documentation included, there is also PURED sticker on the shaft near the grip as you can see in the pic. Used by me a scratch golfer so no club abuse at all
$220 each or best offer , we can work something out.
