Old 11-17-2010, 02:10 AM   #1
motion
Hell Spawn
Coolant LIGHT ON??!?!?
hey guys got a question about this annoying problem I am having with my sisters car.
Its a 2002 Bmw 320i.
When the car is running the coolant light would come on randomly and then go away randomly and i cant seem to figure out why.
i checked the coolant level and all is well.
any ideas boys?
motion is offline   Reply With Quote
Old 11-17-2010, 02:17 AM   #2
check the sensor wiring.
Old 11-17-2010, 09:09 AM   #3
Ceeker
any ideas boys?
check the plug wiring at the sensor. Could be loose or cracked.
1 90 325is white - keepin
1 87 325i vert -red - keepin
KEEPER 88 5sp Vert 2016
Old 11-17-2010, 01:25 PM   #4
Originally Posted by trueblood View Post
it's all in the wiring. what a pain in the ass. I feel bad for you
You feel bad for someone who has a problem which can pretty much be ignored with no ill effects? I should tell you about my cars.
Old 11-18-2010, 05:13 AM   #5
motion
Hell Spawn
LOL.
hey hey hey i still want it fixed just incase i am one day with no coolant and there goes the motor....
Old 11-27-2010, 05:54 PM   #6
hamant
dont worry if u have no coolant yur temp will go up and you'll know it.
hamant is offline   Reply With Quote
Old 12-04-2010, 12:00 AM   #7
Blocked_Out
Your system is not bled properly and you are actually low on coolant !
I had identical problem. Problem is when the car is cold it will show full on the stick in the ET and when the car warms up the coolant light would come on, indicating you are low. When the car cools down so you can check the level, it would shop full, am I right?
Its because of when your thermostat opens it will drain your expansion tank if the system is not bled properly and if its not actually full and you will get a low coolant light on the dash, BUT when it closes > the light will go away.
This is why I ALWAYS tell people to bleed their cooling system when the car is on, because you need the thermo to cycle.
Blocked_Out is offline   Reply With Quote
Old 01-21-2011, 08:02 PM   #8
GTA_G20
Im having the opposite problem. My coolant light comes on at initial startup and goes away after 1 minute
GTA_G20 is offline   Reply With Quote
Old 01-21-2011, 08:08 PM   #9
Ceeker
that's really not a problem. The dme is taking a bit to get the signal from the sensor. Change your sensor. it may be a bit slow..lol remember it's pretty cold outside.
Old 01-22-2011, 06:06 AM   #10
mclovin
How do u bleed it while its on? Turn the car on let it fully warm up with no coolant and then start pouring it in with bleeder screw open?
I'v done it multiple times on my 05 with the car off and never had coolant issues.. level was always right and no flashing cooling lights
mclovin is offline   Reply With Quote
Old 01-22-2011, 07:45 AM   #11
crxgsr
BMW
You need to add coolant. Once the car is running, the temperature rises and the coolant expands, so seems like there is more and the light goes off. Once it cools down, the level goes back down.
crxgsr is offline   Reply With Quote
