Old 11-18-2010, 05:11 PM   #16
bmwconnect
BMW Tuner
bmwconnect's Avatar
Originally Posted by Steve30 View Post
^ its true dynojets read higher because they are inertia dynos whereas a mustang is a load dyno and simulates driving on a road. btw i'm not sure if mustang dynos are calibrated and locked from the supplier but that may be a cause for reading higher. Dynojets on the other hand are calibrated and locked from the factory. Dynos shouldn't really be compared because there will ALWAYS be some variability, its just how the universe works. The best use is to compare you own cars previous performance to its current performance and even then its a bit iffy seeing as the same car can give is a range of hp readouts.
+1 well said!
Old 11-18-2010, 05:36 PM   #17
DR.ZED
Originally Posted by EMPOWERD View Post
years ago, I got the same sort of results with my built M20B27 stroker. Heavy headwork, extrude-honed intake, flow-matched, 273 cams, bored TB, M30 MAF, 19# injectors, jacobs ignition, intake/exhaust, 4.10 gears etc... got so fed-up spending money on NA mods to see marginal gains that I eventually went with a 80HP shot of NOS. Ran that way for 2 years and didn't regret it one bit (proper setup w/progressive controller etc). Surprised the hell out of many IROC/Mustang owners (this is back in '95). Found out how "delicate" the E30 drive-line becomes with near 300ft/lbs! Tearing engine mounts, guibos, center hanger bearing, subframe mounts & diff mounts. Eventually built a 6-pt cage to strengthen chassis & did one of the first M52 swaps (1998)... baselined 222wHP w/bolt ons.. later supercharged it with 12psi.
Some engines are "maxed" out in efficiency from the factory. Not high HP but efficient motors. The S2000 engine is the same way. Only boost or juice will get it really going.
Cam G.
85 325e M5
07 Honda Shadow Spirit 750
Old 11-18-2010, 05:55 PM   #18
NOTORIOUS VR
NOTORIOUS VR's Avatar
I completely understand how they work and why there are differences. That said most load bearing dynos can be calibrated. Regardless, no one will ever be able to convince me that one dyno reads higher or lower then another because it just doesn't mean jack to me. You cannot compare between dynos and blindly saying one style will always read high just is NOT true. I've seen it for myself on more then one occasion.
DJ cannot be calibrated because they measure by the time it takes to spin the drum which is a known the mass.
No one here needs to tell me how dyno's work I'm fully aware of how they work and why, I'm trying to correct an observation here about them always reading higher then a DJ. It's utter and complete BS and it's spread all over the internet.
Old 11-18-2010, 06:27 PM   #19
bmwconnect
BMW Tuner
bmwconnect's Avatar
If both dyno systems are calibrated correctly for the car in question, then the mustang dyno must all ways read lower, as it's simply the law of physics and of course based on how both systems work
here is a good compare video http://www.youtube.com/watch?v=2GI77QHCNSE
IMHO with that said at the end of the day a sixty foot time or QT is much more impressive then any dyno result
Old 03-04-2016, 07:54 AM   #20
AdrianM42
M42 Dyno results
Hi This is my first post ...
I recently had my car on the dyno after replacing my M40 engine with an M42.
The M40 ( +300,000km mileage) motor died after changing into 2nd gear too soon on a 75hp Shot of gas, Anyway...
I want to know how my results compare to other cars . My goal was to build an M42 that was at least as quick as a stock e30 325i.
Here are the details :
Mr turbo dyno was used with no correction factor
1680m above sea level ( Johannesburg , South-Africa )
97kw / 130hp at the wheels
160nm
AdrianM42 is offline   Reply With Quote
Old 03-04-2016, 08:49 AM   #21
DR.ZED
160nm
This is a funny graph, that seems to have been scaled or corrected but I don't get the 160 or 97. Can you show the raw graph HP on the left and TQ on the right where it intersects at 5252... this is the "raw" data that is legit for comparison.
Ya dig?
Cam G.
85 325e M5
Old 03-07-2016, 02:39 PM   #22
AdrianM42
Thanks for your reply.
This is the only printout that I got from the tuner . But I am certain that the results are not corrected.
Im not understanding you well cause the torque and power lines will never intersect the way I see it . The dyno run starts at just over 2000rpm where the torque is already higher than the max power And drops off to just under 120nm which is still higher than peak power. If the dyno was done in HP instead of KW then the graph might intersect somewhere near max rpm. Correct me if I am wrong.
What I also find strange is that I have 2 x 272 cams but the power drops off from 5500 - 7250 rpm - can you advise in this regard please ? Is the power drop at higher rpm normal on M42's ?
Do you think its a good idea to raise the limiter to 7500-8000rpm?
Another thing is that this is not a high compression setup .
Thanks again for your reply.
Old 03-08-2016, 12:22 PM   #23
AdrianM42
Dr. ZED I spoke to the tuner .. he said that he can't show the graph in the format that you asked for
Old 03-09-2016, 10:29 AM   #24
NOTORIOUS VR
Ya dig?
The lines will never intersect because the TQ measurement is in Nm
