Old 11-16-2010, 08:40 PM   #1
audi90qt
audi90qt's Avatar
anyone got dyno sheet for stock m20?
has any1 ever dynoed m20?Dan
audi90qt is offline   Reply With Quote
Old 11-16-2010, 09:39 PM   #2
bmwconnect
BMW Tuner
bmwconnect's Avatar
fresh motor 101kw or 135whp Is what I could find
Old 11-17-2010, 03:55 AM   #3
audi90qt
audi90qt's Avatar
thanks Barry.here is mine.Dan
Old 11-17-2010, 11:32 AM   #4
bmwconnect
BMW Tuner
bmwconnect's Avatar
yup that's all that I could get out of her...two more degrees advance@12.9-13.0afr and dyno was showing power loss so backed it off two degrees on final edit and we have 154whp
Old 11-17-2010, 07:17 PM   #5
DR.ZED
ON A MUSTANG DYNO???? Mustang Dynos 11-12% lower than DynoJets.
What mods are done?
Cam G.
85 325e M5
07 Honda Shadow Spirit 750
Old 11-17-2010, 07:47 PM   #6
bmwconnect
BMW Tuner
bmwconnect's Avatar
Yes a mustang dyno
Cam specs
clearance [cl] 0.25mm 0.25mm
duration [0.1mm+cl] 273° 273°
duration [1.0mm+cl] 236° 236°
valve lift [cl=0] 11.50mm 11.50mm
cam lift
7.25mm 7.25mm
peak angle
110° 110°
timing [1.0mm+cl] 8/48° 48/ 8°
lift at TDC [cl=0] 2.05mm 2.05mm
other mods:
3.5 bar fuel pressure reg
17 lbs injectors of a e36 325i(stock fuel pump,but new)
long header pipe and no cat converter
cold air intake with stock box and airflow meter via removed high beam headlight
20 over pistons,first oversize
mild head porting
shrick valve springs
matched intake and exshaust gaskets
ireland egeneering rocker arms
Old 11-17-2010, 09:49 PM   #7
DR.ZED
I'm not dogging on your engine don't get me wrong.
Is 200 rwhp all for heads, cam, no cat, long tubes and tuning? It sounds like you have some heavy work done, perhaps the 20 over giving a few extra ci as well.
The reason I'm asking is because I am doing a m20b25 swap in my eta this weekend and planned on injectors, tune and long tubes this winter.
Did a bit of searching and stock appears to be 135 - 140 rwhp.
Cam G.
85 325e M5
Old 11-18-2010, 11:26 AM   #8
audi90qt
audi90qt's Avatar
hey..
numbers don`t lie.i don`t think it is quite 200 hp.more like 189 or so.all the mods are listed.it is a combination of all of them together that make such a big difference.i have tried injectors and chip only and gain was there but small.top end was much better with e36 injectors.also,rocker arms very important.i had febi ones when i did engine and they lasted 2 years.i bought set from IE this year.also with cam that i`m running,stronger valve springs are must,specialy with redline i have now.just look at the dyno.car still has 150 hp past 7000 rpm.u can send me PM if need help or advice.Dan
Old 11-18-2010, 12:08 PM   #9
NOTORIOUS VR
NOTORIOUS VR's Avatar
I have a dyno sheet kicking around somewhere on my desktop for a stock SETA with a VEMS standalone that I tuned. I believe it was around 163whp (dynojet @ Tag)
Old 11-18-2010, 12:25 PM   #10
bmwconnect
BMW Tuner
bmwconnect's Avatar
So about 144whp on a mustang dyno /\... It's really too bad that the different whp dyno manufactures vary so much in results
Old 11-18-2010, 02:15 PM   #11
NOTORIOUS VR
I guess, I don't like to assume what the numbers would be on a different dyno because I don't believe in calculations. I've seen all too often that dyno known for being happy or a heartbreaker in fact aren't.
I've seen enough times that DD, mustang etc all read higher then a DJ.
Old 11-18-2010, 03:31 PM   #12
bmwconnect
BMW Tuner
bmwconnect's Avatar
Other way around /\
Old 11-18-2010, 04:46 PM   #13
NOTORIOUS VR
Other way around /\
Are you telling me that I didn't see what I saw with my own eyes?
Old 11-18-2010, 04:52 PM   #14
Steve30
Techno Viking
Steve30's Avatar
^ its true dynojets read higher because they are inertia dynos whereas a mustang is a load dyno and simulates driving on a road. btw i'm not sure if mustang dynos are calibrated and locked from the supplier but that may be a cause for reading higher. Dynojets on the other hand are calibrated and locked from the factory. Dynos shouldn't really be compared because there will ALWAYS be some variability, its just how the universe works. The best use is to compare your own cars previous performance to its current performance and even then its a bit iffy seeing as the same car can give a range of hp readouts.
E36 ///M3 S54
STock 335i "The Punisher"
Steve30 is online now   Reply With Quote
Old 11-18-2010, 05:02 PM   #15
EMPOWERD
EMPOWERD's Avatar
years ago, I got the same sort of results with my built M20B27 stroker. Heavy headwork, extrude-honed intake, flow-matched, 273 cams, bored TB, M30 MAF, 19# injectors, jacobs ignition, intake/exhaust, 4.10 gears etc... got so fed-up spending money on NA mods to see marginal gains that I eventually went with a 80HP shot of NOS. Ran that way for 2 years and didn't regret it one bit (proper setup w/progressive controller etc). Surprised the hell out of many IROC/Mustang owners (this is back in '95). Found out how "delicate" the E30 drive-line becomes with near 300ft/lbs! Tearing engine mounts, guibos, center hanger bearing, subframe mounts & diff mounts. Eventually built a 6-pt cage to strengthen chassis & did one of the first M52 swaps (1998)... baselined 222wHP w/bolt ons.. later supercharged it with 12psi.
My YouTube video
-- RANDY SPARRE --
