Old 11-15-2010, 08:14 PM   #1
talltorontoguy
Go Topless
talltorontoguy's Avatar
Testing Spring Rates
Anyone know of a shop or a DIY method to test spring rates? I've got a set of coil overs with unknown springs and want to test out the rates.
Join BMW Club of Canada! Click HERE
Best Engine, Bimmercruise '10 / 2nd - e30 Wild, Bimmercruise '10 / 1st - Best Cabrio, Trillium @ Tedfest '11 / 1st - e30 Wild, Bimmercruise '11 / 1st - e30 Wild, Bimmercruise '12 www.vertnation.com
talltorontoguy is offline   Reply With Quote
Old 11-16-2010, 01:08 AM   #2
What you can do is get a really fat chick to sit on the coil and see how much it depresses. Fat chicks are easy to find, seeing as they all want lots of attention and sex.
Old 11-16-2010, 07:50 PM   #3
iignite
^ this man speaks the truth
iignite is offline   Reply With Quote
Old 11-16-2010, 08:15 PM   #4
Yeah the fat chick method is pretty much the easiest way to do it. You'll might need two fat chicks though depending on the spring rates.
In all seriousness though if you're going to attempt to load up a spring I'd weld a steel tube vertically to a flat plate to hold the spring, go to the gym and load it up with some of the big free weight plates and measure the deflection
One trick way that might work would be to put a piece of threaded rod through the spring with a plate on the top and bottom of the spring and put a nut on either end of the threaded rod. Then crank the plates together enough to get a deflection measurement and use a torque wrench to measure the torque required to tighten the nuts that much. You can look up the coefficient of static friction for steel on steel (nut on the plate) and determine the Force exerted by the spring on the plate. It should be something like
spring force = 2*Torque / (bolt_size*coefficient_of_static_friction)
Old 11-17-2010, 11:33 AM   #5
InfiniteDice
14 Years with the E30
InfiniteDice's Avatar
Essentially you just need to find out how much weight it takes to compress the spring 1".
Get something with a known weight, then use something to measure the height of the spring like a string. When the spring compresses 1" then that is the weight per inch.
200lb/inch. etc.
You could put the spring in a shop press which has a gauge. I'd be careful and just collapse it one inch which is all you really need to do.
