Old 11-09-2010, 06:10 PM   #1
groovy325
altennator/water pump belt
I recently replaced my altenator belt, in about 3 weeks of driving it snapped, so i put my old belt back on and in about a week it snapped, the pulleys all spin freely. Any hints on what i should check?
groovy325 is offline   Reply With Quote
Old 11-09-2010, 06:18 PM   #2
El Gato Liso
El Gato Liso's Avatar
check for any sharp spots on the pullies.
also make sure nothing is rubbing the belts...
thats pretty much it i suppose.
R.I.P. E30
Old 11-09-2010, 06:23 PM   #3
E30M42cab
Parts Hoarding Specialist
E30M42cab's Avatar
Putting it on too tightly? Check to make sure something like your alternator bracket isn't looks. I've had a bracket break on me which cuts the belt because the sprockets don't line up properly any more.
Grow up and move on.
Old 11-10-2010, 01:21 AM   #4
davericher20
black and blue
davericher20's Avatar
^^ +1 too tight should be a 1/4 inch of play (pressing down on the belt shouldn't exceed 1/4 inch) if that makes sense.
Anyone else?
Old 11-10-2010, 01:47 AM   #5
Ceeker
^^^+2 an over tightened belt can easily snap after some time. Also, over tightening a belt - typically the alt belt can lead to premature wearing of the alt bearing. make sure your alt bearing is spinning freely and the pulleys are lining up as suggested. This can also make the belt snap if there is resistance.
1 90 325is white - keepin
1 87 325i vert -red - keepin
KEEPER 88 5sp Vert 2016
Old 11-11-2010, 07:52 PM   #6
groovy325
Thanks guys, i'll check the list.
Old 11-11-2010, 09:11 PM   #7
overlordjd
bad bearings on the alternator or waterpump can cause small wobble causing the belt to be cut by the outer edges of the pully.
overlordjd is offline   Reply With Quote
Old 11-15-2010, 10:56 AM   #8
groovy325
How can i test for play in the bearings?
Old 11-15-2010, 11:07 AM   #9
overlordjd
if the belt is currently off then you should be able to feel some play when you try to move the pully from side to side. When my waterpump bearing went, it was very obvious and I was able to feel the vibrations created when the car was running.
Old 11-15-2010, 11:38 AM   #10
groovy325
No play, i'm just going to adjust all the pulleys and try a new belt.
Old 11-15-2010, 12:07 PM   #11
craigIS
A.K.A. crossfire291
craigIS's Avatar
Same thing just happened to me. I had my friends shop put the belt on. His boss did the work since I ordered from them. First the belt was loose, and slipping still, then my friends boss tightened the belt. 3 weeks after the belt was tightened it snapped. I suspect it was tightened too much. No one will admit it though.
flickr
Old 11-15-2010, 07:15 PM   #12
E30M42cab
E30M42cab's Avatar
Bearings are a questionable problem for belts to snap really. Like you said, you could feel the vibration, not to mention if the water pump gets that bad, you should be losing coolant slowly at that point as it will be bleeding. If your bearings in your Alternator were that wobbly, you'd hearing it loud and clear.
Your other possibilty could be the alternator bushings being worn out and allowing vibrations.
Old 11-16-2010, 12:53 PM   #13
If one of the items is out of alignment, ie a bracket is bent, it will eat belts. Something else to check.
