Old 11-08-2010, 09:31 PM   #1
givemeanE36
Will these rims fit my M3 without rubbing?
I've decided to replace my OEM contours with a different set of rims, here are the specs:
18x8 fronts 225/40/18 offset is 35mm
18x9 rears 255/35/18 offset is 38mm
Hub bore is 72.56mm, which is a perfect fit for an e30 m3. Will these rims require spacers or hub centric rings to fit on my m3? I am lowered on eibach pro kit so i don't expect any rubbing, my contours in the back have 255/45/17 (which will also be up for sale in about a week if anyone is interested).
Any issues with fit here?
givemeanE36 is offline   Reply With Quote
Old 11-09-2010, 09:31 AM   #2
If you already have that massive tire on it sounds like your fenders are rolled. If so, you'll be fine.
Mystikal is online now   Reply With Quote
Old 11-09-2010, 09:56 AM   #3
givemeanE36
Pretty sure my fenders aren't rolled, mind you my car is barely lowered ~1" all around, but I've never had rubbing issues.
Old 11-09-2010, 10:03 AM   #4
Yeah, even at stock height you'll rub in the back. You need to get them rolled.
Old 11-09-2010, 10:43 AM   #5
givemeanE36
Will I need spacers, heard of rims rubbing suspension components/muffler/etc. At those offsets am I ok?
Also, will I need hub centric rings?
Old 11-09-2010, 11:59 AM   #6
You're good without spacers or rings.
