Old 03-18-2011, 07:58 PM   #61
SamE30e
SamE30e's Avatar
The only probem with no brake booster is you have to REEF on the pedal to get it to stop. I would look into a hydroboost setup.
85 325 - Turbo M52B28.
Old 03-18-2011, 10:10 PM   #62
blk3
blk3's Avatar
any other updates on the project in the drivetrain department?
Old 03-19-2011, 11:09 AM   #63
EuroNut
But there will be a brake booster..it's just remote mounted. The pedal feel should be stock.
No updates in the drivetrain department. Still waiting on my wiring harness unfortunately.
New stainless fuel lines are installed, and so is the new brake master. Pics to come.
EuroNut is offline   Reply With Quote
Old 03-22-2011, 07:53 PM   #64
EuroNut
So I got my steering wheel hub today and just couldn't wait to mount it...
I'm working on sourcing some carpet, and ordered new center vents for it...don't mind the mess, it's storage at the moment.
Started installing my stainless hardlines...yet to be clamped to the body.
And got the braking system started....New master mounted. (Not manual brakes...explanation on previous page)
I've been working on the trunk side of the fuel system, and will update with pics once all the hoses are run.
Old 03-28-2011, 04:49 PM   #65
EuroNut
So I got some more interior peices...new a/c vents, and a bmw horn button
And my fuel lines from the cell to the bulkhead are all done....the rest of the fuel system will be completed as soon as my walboro 255 shows up. I also got word today that my wiring harness will be completed this week, so once i get that back, the motor goes in and should be ready to turn over!
Old 04-11-2011, 02:21 PM   #66
EuroNut
got my fuel pump (walboro 255) and installed it in the stock location.
Old 05-05-2011, 08:48 PM   #67
EuroNut
Ok so I've got a little bit of an update..went to a free parts day and grabbed some stuff.
Got pop-out windows for the rears
A deck lid spoiler (not sure if i'm mounting it or not...)
And got a new set of kidney grills
Also ordered some euro smiley projector headlights to clean up the front end a bit.
Also here's a picture of the newest addition to our shop, it should help out a lot along the way!
Old 05-13-2011, 07:59 PM   #68
EuroNut
so....couldn't keep waiting around for wiring before i made some more progress so here it is...
Engine is in to check clearances and take measurements for a driveshaft and intercooler piping/exhaust!
also installed the clutch/ flywheel and transmisson
shifter location is close
oil pan clearance
little bit of room for a rad
ride height with weight of engine/ tranny
And on a less exciting note, I decided to mount the decklid spoiler and the rear window carpet section
Old 07-15-2011, 08:54 AM   #69
EuroNut
Ok so i have a little update for you guys...
Charge pipes are all done
Catch can is mounted in position
Driveshaft is made (mustang 5L driveshaft with custom 1310 ends)
on to the pics!
lowered it
Old 07-15-2011, 10:55 AM   #70
canuckder
canuckder's Avatar
Sweeet,
I wanted to do this same project, boosted the m30 instead.
The 2j looks so clean in any car, furk. Good job man,
canuckder is offline   Reply With Quote
Old 07-17-2011, 11:22 AM   #71
EuroNut
^thanks
So I got an update on the wiring..shouldn't be anymore than a couple weeks now..everything else is basically done so it should run this year yet!
Old 08-17-2011, 11:07 PM   #72
EuroNut
So I bled my clutch tonight and basically if it stays the way it is now, my leg will look like the hulk at the end of the day...It's very VERY heavy as it is right now. Is there a smaller clutch master that I can use?
Old 08-19-2011, 09:31 PM   #73
Roysneon
Roysneon's Avatar
What are you lowered on?
Old 08-20-2011, 10:46 AM   #74
EuroNut
I cut the springs to see what kind of a drop I'd like...But I'm ordering a set of bc coilovers
Old 09-13-2011, 09:45 AM   #75
EuroNut
I guess I'll upload some pics. of my diff build.
the pumpkin
carrier/pinion out
new races in
Pinion installed
an the new carrier with the graded bolts and washers, and the ring gear and speed ring installed
I then pressed on the bearings, took some measurements and had some custom shims made up as the e30 diff shims are no longer available. And the rear end is all together again.
