Thread Tools Rating: Thread Rating: 6 votes, 3.83 average. Display Modes
Old 06-24-2013, 01:47 PM   #541
ScotcH
Originally Posted by sb_600 View Post
yeah, that's probably a good analysis.
LOL... sounds about right on parts... except I have spare rear rotors already
hold off on ordering though - need to scrounge up some pennies!
No worries ... was just saying what you SHOULD order.
Old 06-24-2013, 02:06 PM   #542
sb_600
sb_600's Avatar
That's DEFINITELY what i'm going to do. No more halfassing/neglecting axles/bearings.
Plus, my axles are identical, so I'll have 1 spare left I can bring to the track
I should probably order new studs while I'm at it too... been running on those for about 4 years now too.... ugh. so many consumables!!!
Shawn
Old 06-24-2013, 03:12 PM   #543
Lercs
Lercs's Avatar
I bet you wish you hadn't of posted up "left the car in the trailer, feels good not having anything to do"
I time to lean is a time to nut and bolt your car!!!
Follow 8legs Racing on Twitter and Facebook
@8legsracing
www.facebook.com/8legsRacing
Lercs is offline   Reply With Quote
Old 06-24-2013, 03:31 PM   #544
ScotcH
Lol ... true. Wish we had time to lean!
You should pull the trailing arms right off and give them a proper de-rusting and paint. And those calipers too ... shiver ...
Old 06-24-2013, 03:41 PM   #545
sb_600
sb_600's Avatar
LOL, meh.... even if I had nut and bolted the car, I never would have thought to check the axle nut... I guess I might have noticed if the wheel bearing was loose but I checked them all for play before the first race and they seemed fine!
Yeah, likely going to need caliper rebuild kits, if not a new caliper on that corner.
I'll have to pull the trailing arms anyway to press the new bearings in, so yup, they'll get a quick sand and paint (time dependant, of course).
Shawn
Old 06-24-2013, 09:46 PM   #546
BigD
the misanthropist
BigD's Avatar
This weekend I finally got around to installing the airbag helper springs on the truck - can't wait to tow again
The springs are fully extended now because the truck is on the lift - at ride height the bags fit perfectly.
How was the install? Were you able to get them in without pulling the coils? I've got a pair coming, heard that this is possible.
Old 06-24-2013, 09:56 PM   #547
sb_600
sb_600's Avatar
Yup, no need to pull coils. You basically compress the bag, plug it and shove it between the coils when they are at full droop. I accidentally installed the first one upside down so I had to take it out- that was annoying but also doable.
Shawn
Old 06-24-2013, 11:19 PM   #548
BigD
the misanthropist
BigD's Avatar
Sweet, thanks! What pressures do you run yours at?
Old 06-24-2013, 11:42 PM   #549
cormier
cormier's Avatar
Not a nice looking failure there dude! Glad you're okay!
Old 06-25-2013, 09:53 AM   #550
sb_600
sb_600's Avatar
Empty trailer = 15psi, full, 25psi. Little stiff but it tows so nice!
Shawn
Old 06-25-2013, 09:54 AM   #551
sb_600
sb_600's Avatar
Thanks! Going to be a pricey fix, but it not much more than it would have been had done the maintenance ahead of time (thankfully).
Shawn
Old 06-25-2013, 10:26 AM   #552
BigD
the misanthropist
BigD's Avatar
Awesome, I can't wait. My 4Runner has plenty of power and brake to tow what I need but the springs are on the soft side.
Old 06-25-2013, 11:08 AM   #553
sb_600
sb_600's Avatar
cool. you in ottawa? do you do any track days around here?
Shawn
Old 06-25-2013, 01:31 PM   #554
SiR
Vtec just kicked in
interesting failure. nice you could recover , pull over nicely and go about your day lol
-||Old Crayons||-
Old 06-25-2013, 02:23 PM   #555
BigD
the misanthropist
BigD's Avatar
No I'm in the GTA so I go to the tracks around here. But I've been to Tremblant a few times, still no Calabogie though - one day.
