Old 11-03-2010, 03:06 PM   #1
E34-Babanca
E34-Babanca's Avatar
Exclamation BMW E34 Coolant Smell in Cabin...
Hi guys,
I have a problem. My 95' BMW 540i blows coolant smell from the vents. I cant use the heat anymore now since all you smell coolant and its quite poisonous. What do i do? I know it must be the heatercore. Also my car gives off alot of white smoke/vapour, even when engine was warm and head gasket was changed a year ago.
Any help? Thanks
E34-Babanca is offline   Reply With Quote
Old 11-03-2010, 03:47 PM   #2
marks525
marks525's Avatar
I would guess at the heater core. Not an easy job. Done that once. Never again.
'07 335i/6 - Addicted to boost
'95 525 - money pit/daily driver
'90 525 S52, ERT Powerdyne Stage 2 Supercharger - parts car
marks525 is offline   Reply With Quote
Old 11-03-2010, 04:18 PM   #3
E34-Babanca
Did you replace the heater core yourself? How much money did it end up costing you? Thank you
Old 11-03-2010, 04:18 PM   #4
ACS_DAN
16/F/Cali
ACS_DAN's Avatar
Do you know if they replaced the head gasket on both banks?
95 530i|Modifications - Work.
ACS_DAN is online now   Reply With Quote
Old 11-03-2010, 04:33 PM   #5
E34-Babanca
Ummm im pretty sure both banks were changed. I know the heater core is probably flooded with coolant, even though the coolant level stays the same...
Old 11-03-2010, 04:48 PM   #6
marks525
marks525's Avatar
I changed the heater core myself. If I remember right, the part was around $300. Shops will charge over $1000 to do the job since it's such a pain in the butt.
Old 11-04-2010, 03:42 PM   #7
JINT
JINT's Avatar
It's not always the heater core, it could be the heater valve or the axillary water pump near the heater valve. Some times those two could leak, and the blower motor just sucks in the coolant smell from the engine bay. I smell the coolant too sometimes inside the car when i turn on the heat. but the smell goes away after 5 seconds.
1990 M5 Euro
You wash your car like it was your firstborn child, you tend to its needs like it was your own body, you protect it like it's your family, then you drive it like you stole it
JINT is online now   Reply With Quote
Old 11-04-2010, 06:12 PM   #8
E34-Babanca
The difference is, no matter how long i leave the heat on, i smell coolant, therefore i believe it would be the heater core...but would be glad to find out its otherwise.
Old 11-09-2010, 01:37 PM   #9
talltorontoguy
Go Topless
talltorontoguy's Avatar
Sounds like you are right - it sure sounds like the heater core. Crappy job but not impossible. There's a writeup on the interweb. Make sure you change the pipes and o-rings while you're in there. Not a job you want to do twice.
Join BMW Club of Canada! Click HERE
Best Engine, Bimmercruise '10 / 2nd - e30 Wild, Bimmercruise '10 / 1st - Best Cabrio, Trillium @ Tedfest '11 / 1st - e30 Wild, Bimmercruise '11 / 1st - e30 Wild, Bimmercruise '12 www.vertnation.com
talltorontoguy is offline   Reply With Quote
Old 11-14-2010, 03:59 PM   #10
zubbie
Happy Happy Joy Joy
zubbie's Avatar
done it. Not hard but lots to disassemble to get at it. In a lot of cases it's just the "O" rings that are leaking.
89 535iA ; 93 M5
zubbie is offline   Reply With Quote
Old 11-15-2010, 08:55 PM   #11
E34-Babanca
Actually, after leaving the heater running for a period of time, the smell of coolant disappears and heat blows nice and hot...
Old 11-15-2010, 09:42 PM   #12
Ceeker
in my experience with e34 the heater taps were faulty. I don't recall cars coming in to get the heater core serviced. Cores usually don't go but may find the o-rings do. As mentioned the heater tap or aux waterpump could be leaking or bad and fan is sucking it into the cabin from the engine bay.
2 IX's -sold and parts
2 325i 4 dr - sold
1 87 325is red - parts
1 89 325i vert grey - parts
1 90 325is white - keepin
1 87 325i vert -red - keepin
Ceeker is online now   Reply With Quote
Old 11-15-2010, 09:50 PM   #13
E34-Babanca
I hope its not the heater core itself and something minor. I'm gonna need to bring it in somewhere and check it out, but I don't know where to bring it to
