Old 10-28-2010, 08:34 PM   #16
hamant
are you sure its as bad as a rumble strip? that doesn't sound like a balancing issue... but you should get the rim replaced to rule it out atleast...
is the rim sitting flush on the hub?
hamant is offline   Reply With Quote
Old 10-28-2010, 10:40 PM   #17
tuan_xi
i took the wheel off today to look at things, and while putting it back on , i notic 3-4mm up and downplay, so im gonna get some rings to rule that out
tuan_xi is offline   Reply With Quote
Old 10-30-2010, 12:56 PM   #18
hamant
sorry, i didn't mean replaced.. i meant rebalanced... the play is most likely the issue..
Old 10-30-2010, 02:43 PM   #19
Aloush
if the there are no vibration on low speeds and only on speeds such as between 80-120 then you need hubcentric rings 100%.. i had tsw's and they certainly need hubcentric rings.
Aloush is offline   Reply With Quote
Old 10-31-2010, 09:14 PM   #20
xlr8nbimbo
I had a similar vibration just after I bought my car. Replaced a new set of "Chinese rotors" with Zimmermans. Cure the vibration for me.
xlr8nbimbo is offline   Reply With Quote
