Old 10-23-2010, 11:39 PM   #1
sol_searchin
E46 facelift 320i - xenon upgrade?
I think i'm to use to having xenon's on all my car's is there a way I can install either a HID kit in OEM headlight's? or get a projector headlight's and install an HID kit without tripping some kind of fault? Anyone have any idea's? I tried searching but found nothing concrete!
I don't need the leveling or bi xenon's just low beam is good enough but something that won't cause a dummy light lol
sol_searchin is offline   Reply With Quote
Old 10-24-2010, 01:12 AM   #2
Seyar
Seyar's Avatar
Just find a pair of projector headlights from one of the sponsors and you won't get any errors
Seyar is offline   Reply With Quote
Old 10-24-2010, 01:52 AM   #3
sol_searchin
which sponsor? link's?
Old 10-24-2010, 02:57 AM   #4
rider-.
eurostyle should be able to hook you up.
Old 10-24-2010, 01:07 PM   #5
ScotcH
A pair of OE xenons is plug and play ... they the plug into the OE bulb sockets and all it fine.
Old 10-24-2010, 01:24 PM   #6
sol_searchin
Ya but my headlight's are the halogen type, so I would have to get oem xenon headlight's and bulbs/ballast's, not sure how this exactly goes together on the BMW I don't need the bi-xenon's/leveling because for that you most likely need programming and screwing around with wiring etc.
Old 10-24-2010, 03:32 PM   #7
ScotcH
You need nothing except the complete headlight assembly. The balast and everything else is integrated ... just plug it in and it works. I swapped with a guy for halogens (I wanted halogens to save weight) and he just plugged them in and was good to go.
Old 10-24-2010, 04:57 PM   #8
sol_searchin
Really? the ballast's are integrated in each headlight also? I guess I will need the non bi-xenon's correct?
Old 10-24-2010, 08:05 PM   #9
RMPMOTORS
RMPMOTORS's Avatar
Some cars will show a error after xenon upgrade, but we can flash the LCM to accept the xenon , and no errors will be on the cluster!
www.RMPMOTORS.com
www.Facebook.com/RMPMotors
Old 11-03-2010, 06:04 PM   #10
Blocked_Out
For your case I will recommend an aftermarket company called DEPO.
Do a search on DEPO E46 headlights.
Reason why? because they are very cheap, great quality and they are NEW.
Reason why I DONT recommend buying from one of the sponsors :
-WAY TOOOOOO expensive
-No matter what you get they will still be 6-11 years old, just like E46 itself and they will most likely look like a 11 year old headlight too.
I have another recommendation for you, move over to E46fanatics.com, mAx is filled with E36 guys, there aint no help for E46 here AT ALL.
Blocked_Out is offline   Reply With Quote
