Old 10-23-2010, 12:10 AM   #16
CoEEzi
I made my clutch stop out of furniture grippers from home depot. I basically stacked 3 of them and put it over my existing one and its held no problem. Also check your break fluid could use a flush.
02 CB M3: KWv3/ OEM LED RETROFIT / CCFL AE / Matte Black Grills / Gills / Dinan Exhaust / Dinan CAI / Dinan stg3 tune/ Dice / 18% Tint All around /
CoEEzi is offline   Reply With Quote
Old 10-23-2010, 12:50 AM   #17
sol_searchin
Thank's for the help guy's, been really busy to get it into a shop so hopefully I'm not doing any damage to it lol
sol_searchin is offline   Reply With Quote
Old 10-28-2010, 11:45 PM   #18
Dan Bro
Dan Bro's Avatar
To make you feel somewhat better, I also just purchased a e46 about 2 weeks ago ( 323i ) and the clutch was replaced about 5000 km prior to my purchase , have all the receipts from BMW dealer to prove it. The clutch pedal does grab high, almost at the tip of the pedal just as you mentioned. It doesn't really bother me I just don't press the pedal in all the way
Replace the fluid, hopefully maybe that will help you out, or try to install a longer "clutch stop" as mentioned in the previous reply's.... Also you can always replace the clutch with an aftermarket one.
Ohh yeah, one more thing:
Clutch Stop DIY:
http://www.clutchstopper.com/clutch-stop-DIY.html
Dan Bro is offline   Reply With Quote
Old 10-29-2010, 02:02 AM   #19
sol_searchin
Ya I just learned to live with it I learned it's a 3 series thing (Not including M3)
Old 11-02-2010, 07:22 PM   #20
ImolaZHP
ImolaZHP's Avatar
Don't increase the clutch stop too much, it will cause premature wear. Also your clutch(assuming its OEM) is self-adjusting, meaning the engagement point will not change regardless of how much it has worn. E46s just have late engaging clutches. Taking out the CDV does help clutch engagement feel though.
Old 11-02-2010, 08:06 PM   #21
sol_searchin
Ya I just got over it didn't want to screw with the OEM-ness of the car
