Old 10-20-2010, 08:19 PM   #1
Bimmer p.i.
Bimmer p.i.'s Avatar
Spark Plugs/Fuel Filter
I am looking to do a swap of the fuel filter and spark plugs - as someone used to doing my own work, is this something that I can do myself, or should I get a trained 'professional'?
Where is the filter on the 2.8? What is needed for the change? My Challenger had it along the fuel line from the carburetor, so all one needed was a screw driver to loosen the 'O' clamps, and voila!
Is the fuel filter accessible without tearing down half of the motor?
...and the plugs? same question - easily accessible, or need to get past a lot of stuff?
thanks guys!
silver 2006 Dodge Charger SXT - performance chip, blue filter Cold Air Intake, 18" chrome 10-spoke rims, custom graphics, leather, custom vinyl interior dress-up, chrome trim package, chrome grill, custom "Punisher" hood badge
Bimmer p.i. is offline   Reply With Quote
Old 10-20-2010, 08:44 PM   #2
its under the car somewhere under a cover, i forget exactly where. follow the fuel lines. its very, very easy. spark plugs too, just make sure you dont leave #4 untorqued and then not notice for a year like i did.
Old 10-20-2010, 08:56 PM   #3
doogee
doogee's Avatar
If you don't know where the sparkplugs or fuel filter are, you might not want to try it on your own.
Search for tutorials online.
Dakar M3 Track Build Thread
Old 10-20-2010, 09:31 PM   #4
///M-TRD3
Modeldater
Both pretty straight forward jobs. But not to worry, you gotta start somewhere. Here is a great DIY for the sparks, keep it open while you do it if you'd like (the pictures should make it very easy to follow). I believe they have the same thing for the fuel filter on that site as well. Goodluck! Like all spark plug jobs, careful when you are threading the new ones in to ensure proper thread/fit.
http://www.pelicanparts.com/BMW/tech...park-Plugs.htm
///M-TRD3
Old 10-20-2010, 09:53 PM   #5
Bimmer p.i.
Thanks guys - I was just popping on to edit the thread as I found a great source for the filter swap - including pulling the fuse. Figure itll save $$ in the long run to do the work myself.
Old 10-27-2010, 02:44 PM   #6
Bimmer p.i.
So I have the filter and will install it tomorrow
my next is about the plugs - is there a particular brand that you guys suggest/recommend?
What is the gap for the 328? Dang, I need a manual.
Old 10-27-2010, 09:12 PM   #7
JvzwetE36325
JvzwetE36325's Avatar
I heard the copper ones are actually the best. I'll check my manual for a gap
1995 325i - Sold
1997 540i/6 - Wrecked
1998 328is M/pkg, Born and raised in Germany - Sold to a Max member
2000 540i/6 - Sold
JvzwetE36325 is offline   Reply With Quote
Old 10-27-2010, 09:28 PM   #8
JvzwetE36325
Ok. My Bmw owners manual says
Bosch F 7 L DC R
NGK BKR 6 EK (my pick)
Nothing about gaps in that, but i got my Haynes right here
Haynes says 0.035 inch (which i believe is standard gap) They also say
Champion RC9YC For 2.5L and 4-cyl
Champion R12YC For 2.8L
Thats all i got, Hope this helps!
Old 10-28-2010, 04:11 PM   #9
Bimmer p.i.
Autovation recommended the Bosch '4'
Fuel filter is changed but I notice that I still have a bit of 'chug-chug'chug' when I give'r. I thought the filter was clogged and starving the engine, now I have to swap the plugs - then if the problem persists - I dunno. :-(
Old 10-28-2010, 04:59 PM   #10
///M-TRD3
Modeldater
Read this thread, it should answer all your questions. Cheers.
http://www.maxbimmer.com/forums/showthread.php?t=109024
///M-TRD3
Old 10-28-2010, 05:55 PM   #11
Bimmer p.i.
thanks for the link - interesting read. I am optimistic that Derek @ Autovation knows what he's doing and will order me the right ones (Bosch '4's he said)
Old 10-29-2010, 11:59 AM   #12
Axxe
Over 9 F**KING THOUSAND!!
Axxe's Avatar
Bosch 4 is garbage. Do not go with them. The simplest copper plug is best, even though it doesn't last the longest it is the best in terms of performance and fuel economy. The bosch 4's are platinum and absolute crap. Had them in my E30 and it ran like shit until I replaced them with OE spec plugs (single ground copper).
Old 10-29-2010, 12:25 PM   #13
Dr. Flyview
"Mint"
Dr. Flyview's Avatar
That would be correct. Return the Bosch 4's.
1998 BMW 328is - summer
1993 BMW 525i - sold
1994 BMW 325i - sold
1992 BMW 325i - gone
sold
Old 10-29-2010, 06:00 PM   #14
5style
Hatters gon Hatt
5style's Avatar
maybe your fuel pump is on its way out, icv, maf leaks, etc, cold temp start switch, that bastard causes some shit
Old 11-02-2010, 01:25 PM   #15
Bimmer p.i.
well I swapped the fuel filter, changed the plugs and gave a good cleaning to the K&N cone filter, and she's running AMAZING (!) like night and day!
I have to go tomorrow and replace the cam sensor cuz it's bunged up, but I think that either the filter was clogged and the engine was starved for air, or a plug wan't firing right, but either way both matters are fixed and she is running great! No chug-chug - just a lotta get up n' go! woohoo!
