Old 10-16-2010, 10:10 AM   #1
xs650boy
e46 vs e90
Is there any difference in offset / bolt pattern / etc. for 16" wheels between e46 and e90?
xs650boy is offline   Reply With Quote
Old 10-16-2010, 10:24 AM   #2
ZiMMie
Offset is a little different but bolt pattern is the same.
Which 16's, the steelies or aluminum?
#E36-S54 #CSLWannabe
Old 10-16-2010, 12:08 PM   #3
xs650boy
I'm looking at some 16" e46 alloys for winter.
Old 11-04-2010, 02:46 PM   #4
MrRWD
i've swapped wheels between my E46 and E90... it will fit....
16" e46 wheels may not clear the e90 brakes... but you've got a 323i... so it might fit..
bolt pattern/offset.. you're fine.
clearance on a 16" might be an issue
MrRWD is offline   Reply With Quote
Old 11-04-2010, 06:01 PM   #5
xs650boy
But if I have 16" now I should be good right? I hope so, I already got them!
Old 11-04-2010, 08:09 PM   #6
pawcio
pawcio's Avatar
yes
__
Old 10-22-2013, 11:36 AM   #7
mrod
Reviving an old thread as my search didn't help.
Will all E90 rims fit on an E46 properly?
Looking for snows and the E90's are sooo much nicer.
mrod is offline   Reply With Quote
Old 10-22-2013, 11:42 AM   #8
Yes, E90 non-M wheels fit an E46. The wider rear Sport Package setups with 255s will sometimes require a fender roll. But for narrow snows, no problem.
Old 10-22-2013, 12:58 PM   #9
dtthiaga
Having owned both at the same time, I've changed things up.
The 18" Sport E90/E92 rims, with 255 tires work really nice on a E46 with sports suspension.
E90 snows should be fine. Get thinner tires. Walk away from anything wider that 225 on a E46 for the winter.
Old 10-29-2013, 10:19 AM   #10
mrod
Thanks guys.
I picked up a set of these.
Old 10-29-2013, 11:20 AM   #11
Perfect. Run 205/50/17 or 225/45/17, the former preferred.
Old 10-29-2013, 12:20 PM   #12
mrod
Yup.
Came with Blizzaks 225/45/17
