Old 02-17-2011, 09:28 AM   #31
Adrian_Lindn
Adrian_Lindn's Avatar
I put on some dressing for now. I think i need to use a stethiscope to diagnose exactly what it is. Anybody else ever have this squeeking sound(obviously) any suggestions brothers
Adrian_Lindn is offline   Reply With Quote
Old 02-17-2011, 11:20 AM   #32
Adrian_Lindn
Honestly, The sound kind of sounds like bearings rubbing....I think something needs to be changed here....
Old 03-04-2011, 12:49 PM   #33
Adrian_Lindn
So i changed the drive tensioner pulley since it was effed,,,,and the noice still persists. I found that my idler pulley is spinning to freely as well, does anyone know if the idler pully can be making this noise?
Old 03-04-2011, 01:07 PM   #34
E36is
'OldSchool..'
E36is's Avatar
there is two pulleys. one on the tensioner and one that is an idler. if you only changed the one on the tensioner then the idler pulley is the culprit. Or it could also be your steering pump, water pump, alternator, AC condenser, all of them have bearings.
Old 03-04-2011, 01:10 PM   #35
Adrian_Lindn
you think my next best bet is changing the idler?
Old 03-04-2011, 03:42 PM   #36
Adrian_Lindn
┬┐any takers
Old 03-06-2011, 09:54 PM   #37
yeah, i'll take a stab at it. Change the belts.
Old 03-08-2011, 01:15 PM   #38
andrew.k
Top Gear Professional
andrew.k's Avatar
Ahhhhhhhhhhhhh change the belts already
330i | M Technik | BBS 197 | 3D Studie | H&R
andrew.k is offline   Reply With Quote
Old 03-10-2011, 05:12 PM   #39
Adrian_Lindn
Going in to change the idler pulley tonight....fingers crossedd
Old 03-14-2011, 01:58 PM   #40
Adrian_Lindn
Changed the Idler, now it sounds even worse...A whistle/screeching.....how is this possible? does this mean the alternator/ac/or water pump are ****ed since the tension is back to normal b/c of the new idler n tensioner pully? Any body else ever have this prblem....starting to get irritating
Old 03-14-2011, 05:49 PM   #41
E36is
'OldSchool..'
E36is's Avatar
did you change the belt?
Old 03-14-2011, 10:00 PM   #42
Adrian_Lindn
No the belt is fine, checked it...no cracks no nothing....I have nooo idea
Old 03-15-2011, 10:18 AM   #43
Adrian_Lindn
all 3 other pulleys?
Old 03-15-2011, 10:57 AM   #44
mclovin
How old are these belts? Rubber compount in these belts deteriorates and over time they become very hard. Try new belts man.. i think its in the area of 50$ for both
mclovin is offline   Reply With Quote
Old 03-15-2011, 11:05 AM   #45
Adrian_Lindn
I have not changed the belts since i bought the car about 2 years ago now. Im not sure if the previous owner did. But in all seriousness i dont think that the belts would make that much noise?
