Go Back   maXbimmer Forums > Platinum maXbimmer Sponsors > StanceFactory
Welcome to!
Closed Thread
Old 10-06-2010, 01:56 PM   #1
Exclamation Inspection II BLOWOUT SPECIAL! - StanceFactory
It's that time of year again, when summer events slow down and it's time to pay attention to our car maintenance needs. We've crunched the numbers, and we're proud to offer the maXbimmer community the lowest Inspection II prices ever seen in the GTA.
How low? First, let's go over what's included:
Inspection II
1. Change engine oil and filter oil while engine is at normal operation temperature.
2. Check transmission for leaks.
3. Check rear axle for leaks.
4. Visually check fuel tank, lines, and connections for leaks.
5. Check condition, position, and mounting of exhaust system. Examine for leaks.
6. Check power steering system for leaks.
7. Check overall thickness of front and rear disc brake pads.
8. Examine brake disc surfaces.
9. Clean brake pad contact points in calipers.
10. Grease wheel center hubs.
11. Check steering for absence of play, condition of suspension track rods, front axle joints, steering linkage, and joint disc.
12. Check front control arm bushing for wear.
13. Check brake and clutch system connectors and lines for leaks, damage, and incorrect positioning.
14. Check for free movement of the parking brake cables. Adjust parking brake if necessary.
15. Check all tire pressures (including spare). Correct if necessary.
16. Check condition of tires (outer surfaces (left/right)), tread wear and pattern; In case of uneven tread wear readjust wheel alignment if required.
17. Check thickness of parking brake linings.
18. Half-shafts; check for leaks at flexible boots.
19. Inspect entire body according to terms of rust prevention limited warranty.
20. Replace fuel filter (not required, but we do it)
Engine Compartment
1. Read out diagnostic system
2. Check engine cooling system/heater hose connections for leaks.
3. Check coolant level and antifreeze protection level; add coolant if necessary.
4. Check level of brake and clutch fluid in reservoir; add fluid if required.
5. Check windshield washer fluid level and antifreeze protection. Fill up and/or correct if necessary.
6. Check air conditioner for operation.
7. Reset Service Indicator.
8. Replace spark plugs.
9. Replace intake air cleaner element.
Body/Electrical Equipment
1. Check battery electrolyte level and add distilled water if required.
2. Perform batter load test.
3. Check lighting system, i.e. headlights, foglights, parking, backup, license plate, interior (including map reading lights), glove box, flashlight, illuminated makeup mirrors, luggage compartment lights.
4. Check instrument panel and dashboard illumination.
5. Check all warning/indicator lights, check control.
6. Check turn signals, hazard warning flashers, brake lights, horns, headlight dimmer/flasher switch.
7. Check wiper and washer system(s); wiper blades, washer jet positions.
8. Check condition and function of safety belts.
9. Oil hood, trunk/tailgate, and door hinges.
10. Grease hood, trunk/tailgate and door latches. Check operation of all latches.
11. Check central locking/double lock.
12. Replace microfilter or Acc Cabin Filter.
13. Check heater/air conditioner blower, rear window defogger.
14. Check rear view mirrors
15. Visually examine the SRS airbag units for torn cover, obvious damage or attachment of decals, decorations, or accessories.
Final Inspection
1. Road test with check of brakes, suspension, steering, clutch/manual transmission or automatic transmission.
All parts used are OEM BMW (Mann, Mahle, Bosch, etc) except where better is stocked (NGK EQUP plugs). Engine oil is 5w30 BMW LL-01 except for the E46 M3 and E39 M5 where 10w60 Lubro Moly high performance oil is used.
Pricing (plus tax!):
E36 6 cylinder (inc M3): $350
E46 non-M, E39 6 cylinder, X3 (all): $400
E39 540i: $450
E38 740i/iL, X5 3.0: $500
E46 M3, E39 M5: $550*
*E46 M3 valve inspection (including new valve cover gasket) $120 extra. If valves require adjustment price will depend on amount of shims needed.
Please call us and book your appointment today!
Mystikal is offline
Old 10-06-2010, 05:51 PM   #2
Seyar's Avatar
That's great price guys, I would say cheapest anywhere in Ontario.
Seyar is offline
Old 10-06-2010, 10:46 PM   #3
Amazing pricing...
damameke is offline
Old 10-07-2010, 04:57 PM   #4
Sound Great! how about fuel filter is it extra for the E46 330? Is it 2 years warranty on your parts and labor replacement too? I know a shop they have a stardard policy just like dealer, give out 2 years warranty with parts and labor. But price are lower then dealer, but higher then what you charge for the inspection service. But I think you can offer the same warranty too?
daily996 is offline
Old 10-07-2010, 05:49 PM   #5
Fuel filter replacement is included with all of the Inspection II prices we've listed above.
As for warranty we match the dealer, which is 1 year parts. There is no labour warranty, here or there.
Mystikal is offline
Old 10-07-2010, 05:59 PM   #6
Thanks for the quick respond, it is a great, but youo only give one year on parts warranty, if is the defacted parts I have to paid the labor! For that shop they do have the labor and parts NO CHARGE for the WARRANTY period. If you don't mind I can post the company name for our maxbimmer members
daily996 is offline
Old 10-07-2010, 06:28 PM   #7
I'd rather you not try to advertise another business in our sponsor section.
Our goal is to match the dealer's service, at approximately 1/3rd of the price. We hope max members can appreciate just how great of a deal that is on its own.
Mystikal is offline
Old 10-08-2010, 12:21 AM   #8
mpower1226's Avatar
I assume that z4m would be under the category of e46m3 price?
once my mcoupe arrive, I would like it to have inspection II done including valve adjustment. Right now I am trying to pressure dealer to pay for the inspection ii.
mpower1226 is offline
Old 10-08-2010, 11:27 AM   #9
A few of the unique M Coupe parts cost more, but we'll honour the same price as the E46 M3. Really I just like that car a lot.
Let me know when you're ready.
Mystikal is offline
Old 10-08-2010, 10:16 PM   #10
Driving in the fast lane
slemmer's Avatar
I cried when I saw your price for the e38 after thinking back what I paid at the dealership.
'15 Ford F150 Lariat SCSB 4x4
'04 645cic
'00 740i Sport
slemmer is offline
Old 10-08-2010, 10:51 PM   #11
mpower1226's Avatar
tranny fluid change included in inspection 2?
Old 10-09-2010, 07:51 AM   #12
Transmission and diff fluids are not included.
Mystikal is offline
Old 11-14-2010, 08:37 AM   #13
Top Gear Canuck
Supreme_sole's Avatar
how long is this deal on?
Supreme_sole is offline
Old 11-14-2010, 11:36 PM   #14
Romaz's Avatar
Just got mine done few days ago. Thanks again guys, car is running nice and smooth now! Stance Factory ROCKS!!!
Romaz is offline
Old 11-15-2010, 12:29 PM   #15
Is this inspection II recommended for E30's?
row155 is offline
Closed Thread
