Old 10-03-2010, 09:34 AM   #1
brent-E30
boost junkie
brent-E30's Avatar
1990 325i Turbo 366WHP new pics! price drop
BODY
- NO rust. car was garage kept since 93 and has not seen winter since then, sprayed at crown every year too.
- Paint, the car had original paint until 2 years ago when i had it painted, i wanted the deepest black you could get and i got it. the cars clear coat is a new clear coat only used by Mercedes-Benz i think so far, its self healing clear coat, its sun activated. the car had no rust before i painted it i have pics to prove that.
- 15% tint all around, 55% windshield. Professionally applied.
- Fiberglass MTech2 front with splitter, Mtech2 side skirts and rear all done by Eurostyle. a real Mtech 2 spoiler plastic, the manufacture date i forget what it said but it the year was 1988. the car also comes with a badboy eyebrow if you want it.
- OEM fog housings, with 3000k 35w HID's very Yellow
- antenna shaved when i had the car painted.
- smoked taillights and side markers and hi beams as you can see
Wheels
-direct fit ESM stagered 17" rims (silver) front 7" and rear 8.5
-tires are Kumho Ecsta supras and are 215/40/17 front and 235/40/17 rear and tuck nicely.
Interior
- Black leather IS sport seats, heated, all in excellent shape.
- Black headliner
- Auto meter boost and oil pressure gauges (mechanical)
- afr gauge as shown
- Power everything, all functional
- A/C gone. saved 42 pounds
- Uncracked dash
Engine
- 214000kms
- Stock bottom end, ARP head bolts, torqued to 71 ft-lbs
- 72lb lucas injectors
- Exotic speed tubular exhaust manifold, (looks like the ebay one but fits better.)
- Holset HX-50 turbo with 21cm exhaust housing.
- 2.75" charge piping, 21x12x3" intercooler
- GReddy Type-RS BOV (not a knockoff)
- tial 38mm wastegate
- Hallman manual boost controller, in cabin
- Rebuilt head with welded water jackets
- 282 cam
- timing belt and water pump done in the last 15000k
- 255lph pump in tank
Exhaust
- 3.5" mandrel bent till under the passenger seat the splits to two 2.5" pipes that go to two magnaflow cats and two magnaflow mufflers, (i wanted it to not sound boomy) flex pipe in downpipe
- Magnaflow tips
Management
- Megasquirt 2v3 mainboard, native USB converted - everything fits inside stock ECU box, plug and play
- Innovate LC-1 wideband o2 sensor
- GM IAT sensor tapped into charge piping
- GM wasted spark coil pack packs as seen in pictures (i'm using ngk brp7es plugs and bosch wires)
- Tuned very nicely thanks to Greg (furyriderx) its been running more then 10psi for 3 years now with no bottom end problems at all. its tuned to 17psi
- 91 or higher octane
- Starts and idles nice
Drivetrain
- lightened flywheel
- 3.73 LSD swaped in.
- Eurodrive clutch 4 puck unsprung disk with stage 2 pressure plate.
- Threw in a shot shift wile i was there
Suspension
- Air ride, there was no kit for this car when i did it so i made it all, it can be changed back to coilovers with not much work though.
- Viar pump, small tank in trunk. purge switches in cabin (yellow ones, i'm sorry its all the store had left lol)
- Koni Yellow sport shocks all around
- eiback PRO kit (red) sway bar kit with bushings (adjustable)
Audio
- Alpine CDA 9833 deck
- JL audio 500/1 slash series amp pushing a 10" W7 sealed and ported into the cabin
- Jl audio 300/4 slash series amp pushing component 6.5 and tweets in the back and 5.25 and tweets in front. all with fiberglass enclosures except sub
- 1 fared capacitor and 2gauge wires to amps
- professionally tuned
Performance
-The car makes 366WHP last time i had it dyno'd at 16~17psi. if its a 17% drivetrain loss (witch i might be wrong but thats what i found anyway) its about 428 flyweel hp
I'm sure i'm missing lots of things but anyway, the car runs great, very fast as you can imagine, i'm only selling because i need the money and dont want two cars anymore.
the car gets not bad gas millage actually
i know i've spent over 20,000$ on this car not including time but i know how much its worth so im not going to ask like 15000 for it, so the price is 8,300 OBO as is. without sound system. if your interested in the sound system we can work something out. thanks for looking
brent-E30 is offline   Reply With Quote
Old 10-03-2010, 09:35 AM   #2
brent-E30
boost junkie
brent-E30's Avatar
Old 10-03-2010, 09:38 AM   #3
brent-E30
boost junkie
brent-E30's Avatar
ill take 7200 with stock wheels on it and no sound system also, and i can take more things off to make it the price lower too. the car is on the road and driving for one more month before it gets put away for the winter.
Old 10-11-2010, 06:00 PM   #4
brent-E30
boost junkie
brent-E30's Avatar
Make an offer, bump
Old 10-16-2010, 06:06 PM   #5
brent-E30
boost junkie
brent-E30's Avatar
ill take 6800 no wheels no sound system.
Old 10-18-2010, 12:33 AM   #6
brent-E30
boost junkie
brent-E30's Avatar
Bump
Old 10-18-2010, 12:11 PM   #7
black bnr32
black bnr32's Avatar
what are the cables next to the shifter?
comes with original door cards?
black bnr32 is offline   Reply With Quote
Old 10-20-2010, 11:45 PM   #8
brent-E30
boost junkie
brent-E30's Avatar
Air lines. And I can get more door cards if you want, or I can give you the door cards for free. But those are the ones that came with the car just with fiberglass pods on them.
Old 11-28-2010, 01:40 AM   #9
brent-E30
boost junkie
brent-E30's Avatar
Last bump till spring
Old 11-28-2010, 01:36 PM   #10
MBrown
MBrown's Avatar
wow this car is insane! looks like you put a TON of time into this thing!!
just wondering.. why you selling it?
1995 US-Spec Boston Green M3
18x8.5 MK Motorsport MK1's, BavAuto F+R Strut Braces
UUC System U Catback
MBrown is offline   Reply With Quote
Old 12-09-2010, 10:05 PM   #11
booms_328is
interested in your e30
very nice e30, I'm very interested in your 325i whats your email address. We'll talk on there because I'm never on this site thanks.
booms_328is is offline   Reply With Quote
Old 12-13-2010, 01:53 AM   #12
msinger
very nice!
msinger is offline   Reply With Quote
Old 12-18-2010, 07:20 PM   #13
JSPEC
Hey bro would you sell the rims?
JSPEC is offline   Reply With Quote
Old 12-19-2010, 06:17 PM   #14
JSPEC
How much for the entire car without taking anything off? If we can work something out then I will buy it for sure when it comes out of storage and give you a deposit of some sort now so that it is a deal for sure. Then when it comes out of storage I will just pick it up with the rest of the cash. Let me know bro. You are asking for 8, 300 so I was thinking something like 9000-9, 400.
Old 12-28-2010, 12:14 PM   #15
brent-E30
boost junkie
brent-E30's Avatar
car is sold sorry the rims are for sale though. just putting the add up now for them
