10-02-2010, 11:52 AM
#1
E30 POWER
Car: e30 327I TURBO
turbo car wont start,,,need help
so i got the car all together ..started the car up and she fired rite up,,started putting coolant in it and had heat coming out the vents so i thought she bleed through proper......so i just let the car sit there and idle cause i had oil problums before so i was just letting it burn off all the oil and smoke ,,,,,so after 30 min of idleling she seemed ready to go,,,so i took her out for a drive and within a 2 min she started overheating,,,so i shut her down and put her away for the nite
so i went to start it the next morning and she started and bogged for a min or so then stalled and now she wont go at all ,,,,its not even trying to turn over ,,completly dead,,,,,i checked for spark and i have spark to all 6 cylinders and i have fuel aswell,,,,,,everytime i take out a plug ,,there just soaked in fuel almost as if its getting tommuch fuel,,,,but ive been running these injectors for a while now and never had any problum(30lbs)
i dont now where else to look as to why this thing will not fire up after she overheated,,,,,so any help would be great
thanks
10-02-2010, 12:19 PM
#2
Car: e36 m3
You said it's not even trying to turn over?? How can you check for spark if tr engine isn't cranking?
If it really isn't cranking you should start with the battery/grounds/connections/etc, then starter.
10-02-2010, 12:22 PM
#3
Car: 328i & 327i turbo
edit: ^ you beat me to it while I was typing my response
Sorry, you're saying it won't turn over at all as in the starter wont crank it? You said you checked spark, you wouldn't be able to do that if it wasn't turning over.
If it's not cranking first thing I'd do is check the battery, after that check the ground cable that goes from the chassis to the oil pan.
If it's cranking but not starting... by the sounds of it you're running the car on the stock DME and you're saying it's getting too much fuel? Do you have a RRFPR? Maybe one of the adjustment valves shifted?
10-02-2010, 12:25 PM
#4
Car: e30 with e91 beater
Confusing.. post details about your setup, as detailed as possible so we can better help.
10-02-2010, 03:51 PM
#5
E30 POWER
Car: e30 327I TURBO
sorry,,,,,,,its turning over but not even coming close to trying to start ,,,,,,its just sitting there cranking
sorry typo error
10-02-2010, 03:55 PM
#6
E30 POWER
Car: e30 327I TURBO
didnt say its getting to much fuel ,,,said the plugs r soaked of fuel after trying to start and then pullin them out and checkin them,,,,,,,,the car ran fine with the rrfpr and 30lbs ,,,started up great and idle fantastic,,,,,,untill it over heated and now its not even trying to start,,,,,,,,,turning over but not fireing up or even trying to fir up
10-02-2010, 07:40 PM
#7
Car: e36 m3
Did you Check compression?
Overheating it could have blown something.
02-13-2011, 02:51 PM
#8
E30 POWER
Car: e30 327I TURBO
alright guys i havent worked on the car in 3 months and am going to get back in to it
tryed starting it up same problum ,,sits there and cranks but will not fire up,plugs r soaked of fuel
my setup is a hc1 holset with 30lbs injectors,rrfpr and stock computer.plugs r ngk bpr8es
i am going to purchast the 55 pin pnp megaskurt but would like to get the thing running first,,,so anyhelp would be great. any questions dont hesitate to ask
02-13-2011, 03:19 PM
#9
BMW Tuner
Car: BMW 330CI
stock programming with 30LB injectors and a RRFPR = way to much fuel
The BRP8ES plugs are very sensitive to fouling
I am willing to bet your oil stinks of gas also
a process of elimination is the best way to pin point your problem even if it means checking things over twice
all the best
02-13-2011, 08:39 PM
#10
Over 9 F**KING THOUSAND!!
Car: '91 325iS | '96 332i
make sure you have juice at the coil with ignition on
