Old 09-29-2010, 11:10 PM   #16
3x Beemer
Originally Posted by doogee View Post
Not positive about the diff play.
The CDV is before the clutch slave cylinder. On the drivers side of the tranny.
The brakes and clutch don't share the same "cylinder" but they do share the same fluid reservoir.
So you just remove the fitting in the red arrows and the hose will thread right into the stainless line? Think the clutch will need to be bled?
03 AW on LSB M3 coupe, BMW motorsport 4.10 Diff, AA Exhaust, OEM CSL rims, Aero Res, TMS subframe, powerflex bshgs, Macht Schnell, Vorsteiner diffuser, TMS steel lines etc..
Complete Comp Pkg Upgrade
98 328is hamann HM2,3.23 diff, ZKW headlights, HID fogs, M3 front, sides, rear and mirrors.UUC rsc36 exhaust, fk coilovers, X brace,UUC tran mounts. Spal fan, Mishimoto rad, AKG rtab, Pweflex CAB. Rogue RSM,SS clutch line, m3 subframe plates, pf bushs
09 F250, 2012 Honda CRV winterbeater
3x Beemer is offline   Reply With Quote
Old 09-29-2010, 11:32 PM   #17
doogee
Stance is Gay.
doogee's Avatar
Exactly.
You'll probably need to bleed the clutch a little bit.
Dakar M3 Track Build Thread
Old 09-30-2010, 06:57 PM   #18
iverson03tj
So i changed the clutch, it drives nicely, just waiting on 4 bolts n a gasket for my exhuast, since i had to cut the old bolts up. Also did the cdv delete finally one problem done... few more to do, thank you all once again for your input!!
Old 09-30-2010, 07:05 PM   #19
Steve30
Techno Viking
Steve30's Avatar
What do you think of the cdv delete? I'm thinking about taking mine out this weekend.
E36 ///M3 S54
???whp E30 coming soon.
Old 09-30-2010, 07:15 PM   #20
iverson03tj
I will let you know tmr cant wait to drive it once my exhaust is on
e30 325ic -
PREVIOUS CARS
'01 Audi A4 B5
'96 Civic B16
'95 Acura Legend Type II
'97 Euro Estroil E36 M3 Vert
Old 10-01-2010, 12:02 PM   #21
iverson03tj
Ok so i went for a nice run and i gotta say it feels WAY better without the cdv... i can make my tires chirp now on 2nd gear.
And also its the easiest way to do a burn out... well not really a burn out.. i launched at 3k rpm and before when i tried to do that the cdv delayed it, now it doesnt do that.
e30 325ic -
PREVIOUS CARS
'01 Audi A4 B5
'96 Civic B16
