Old 09-24-2010, 08:31 AM   #1
SamE30e
SamE30e's Avatar
1991 BMW 318is M50 Swapped E30
Hey,
I'm selling my M50nv swapped E30. I did the swap a year and a half ago. I'm selling it because I need something newer for my commute to school and a change of scenery.
Body
450,000 on body (swapped clusters because of bad speedo and ODO gears (says 30x,xxx)
Replaced front fenders (flat black)
Replaced sunroof (Dark blue)
Replaced trunk lid
Minor rust on body, all repairable.
Underside is super clean and solid
Car would need a paint job and some body work.
Volvo front lip
iS rear spoiler.
Passenger door is dented pretty bad (Person before me rode a lamp post or something but is fixable and not very noticeable from 20 feet)
Engine
M50Nv
200,000km on the engine
Fresh rebuilt head.
ARP Head studs
Minor port on head
New valve stem seals
New valve guides
Head was hot tanked and cleaned
Always run synthetic since I've owned it
Every single gasket was changed when I did the swap and head rebuild.
New rear main seal
Engine doesn't drop one bit of any fluid
New cam sensor
New coolant temp sensor
Newer MAF
318is engine wiring covers
Dinan 91 octane ECU
14" E-fan, wired to stock wiring. (You can turn it on, or it comes on automatically)
80 degree T-stat (brand new with the head)
Top end rebuild has about 2000km on it, and when I say every gasket was changed, I mean EVERY gasket was changed.
Exhaust
Superspring replica stainless long tube headers
2.5" Stainless single mandrel bent piping
Vibrant Cat
18" stainless resonator
Vibrant 2.5" in/out Street power sleeper muffler
Brand new O2 sensor
Exhaust was done 2 weeks ago at JPG, cost me about 700$, I have the reciepts for it.
Engine pulls hard, I've been told that with 19lbs injectors and a Millar W.A.R tune it should make 200whp, but realistically 190whp is possible. (Which would put you in the 13's in an E30 and would be pretty quick but not overpowered). I have a set of 19lbs injectors I'll include. I had them in the car and it pulled like a mother, but I reset the ECU and had to put all the stock ones back in.
Transmission
Euro 323i M20 flywheel, lightened to 11lbs
M20 friction disk
Sachs pressure plate (I think it's a HD one, I bought it off someone who didn't know what it was, I never checked the part number, but it is pretty stiff and is impossible to slip)
New TOB and Pilot bearing with the swap
Z3 1.9 short shifter
Solid bushings on the shift carrier and all other bushings replaced
New CSB
4.10 LSD (Works well)
Suspension and Brakes
H&R Sport springs
Tokico HP struts (Fronts have maybe 5000km on them)
Ireland Engineering poly urethane rear subframe bushing
Sparco front upper strut bar (Red and beefy)
Has a newer steering rack that doesn't leak
Brembo blank rotors
PBR pads with lots of life left
Stainless steel and coated brake lines.
All new ball joints
Interior
Nardi leather wrapped wheel
Sparco shift knob
E30 sport interior with no real major flaws except some wear on the driver seat, but no rips.
Autometer AFR gauge (Narrow band, not very accurate but looks cool)
Has a deck in it, wired to the premium stereo with a 12" MTX sub and amp, but that would cost extra as I can use it in a new car. I would put a Panasonic MP3 deck with aux in if you didn't want it.
Sunroof was converted to Electric, but just needs to be wires
Oh, and super dooper rare (I've heard and been told) OEM black headliner.
Wheels and tires
The car comes with stock 14" weaves, 2 tires are shot.
Also comes with a set of 16x7.5 TSW Hockenheims with BRAND NEW (500km on them) Goodyear Eagle F1 gt's (Expensive and awesome tire) 215/40/16. Wheels are a FWD offset, so I have a set of T6061 aluminum 20mm front/15mm rear hubcentric spacers, that are fairly new.
Overall the car is mechanically solid, the only thing I think it needs is a Diff bushing (Which is a 20 minute job) and front LCAB's (Which I will include and possibly do before it's sold) and body work. I'm asking $4500, but am open to reasonable offers. If you're going to offer me $2000, don't even bother. If you come to look at it, I'll take you for a ride, you're not driving unless you have cash in hand (It's not because I think it's a Ferarri, it's just because I don't trust you.)
I will put more pictures up as soon as I can, you can PM me to get a hold of me. This car isn't perfect, but is a good base for a clean E30. I was planning to paint it but school, time and funds wouldn't permit that. I've been told it's one of the cleaner swaps, and I believe it after seeing some of the hack job 24v swaps.
PM me with any questions.
Sam
85 325 - Turbo M52B28.
SamE30e is online now   Reply With Quote
Old 09-24-2010, 08:59 AM   #2
El Gato Liso
El Gato Liso's Avatar
This car is worth more than the asking price. Seen it in person and it makes me jealous...sometimes :p
Sad to see it online for sale! Just don't sell it to some punk ass kid who will write it off.
GLWS
R.I.P. E30
Old 09-24-2010, 09:41 AM   #3
dgmorr
Were you satisfied with JPG?
Old 09-24-2010, 09:59 AM   #4
SamE30e
SamE30e's Avatar
Yeah, more then satisfied. They did amazing work for the price, and are amazing people there.
Old 09-24-2010, 12:06 PM   #5
sick car broooo
Seriously tho, glws.
Old 09-24-2010, 05:09 PM   #6
Bainze
Dogleg
Bainze's Avatar
does it have the late e30 brakes? vented front and rear disks?
Bainze is offline   Reply With Quote
Old 09-24-2010, 05:52 PM   #7
SamE30e
SamE30e's Avatar
It has vented front, I don't think E30's came with vented rears. But they are late model brakes, I don't know how much of a later model you can get than a 91 seeing as how it was the last year they made them.
Also on a side note. The ABS works flawlessly, which is not very common on E30's.
Old 09-24-2010, 08:13 PM   #8
SiR
Vtec just kicked in
hhe, saw you rip it a couple weeks ago. Car sounds great and it moves!
as long as you dont buy an audi its ok
-||Old Crayons||-
Old 09-24-2010, 08:45 PM   #9
SamE30e
SamE30e's Avatar
I'm looking for a B5 A4 1.8t or a WRX.
Old 09-24-2010, 09:43 PM   #10
dgmorr
Not me, but...
http://www.audizine.com/forum/showth...3-2001-Audi-S4
Old 09-24-2010, 10:29 PM   #11
You should wrap the fenders in vinyl to match
Old 09-25-2010, 12:56 AM   #12
SiR
Vtec just kicked in
thats gonna cost you more in gas...
-||Old Crayons||-
Old 09-26-2010, 12:30 PM   #13
SamE30e
SamE30e's Avatar
My brothers B5 got 700 to a tank.
And I want something more updated.
Old 09-26-2010, 11:27 PM   #14
SiR
Vtec just kicked in
maybe highway...but the suby will chew gas. worse than a bmw. just sayin. I can totally understand the want for something newer.
good luck with the sale. its a great ride.
-||Old Crayons||-
Old 09-27-2010, 04:46 PM   #15
hosty
hosty's Avatar
B5 a4 is what I'm going for next!
hosty is offline   Reply With Quote
