Old 09-22-2010, 10:45 AM   #1
JvzwetE36325
JvzwetE36325's Avatar
Question Cam Grinds
I found a shop that can grind my cams, so now the question is....
How wild should i go? I dont mind loosing a little bottom end,
From what i've researched stock cam specs are as follows
M50TU
Duration 228 / 228
Lift 9 / 9 *mm
S50
Duration 252 / 240
Lift 10.2 / 9.7 *mm
Schrick
Intake - 264 degree, 11.2mm lift
Exhaust - 256 degree, 10.6mm lift
I wanna go a little more aggressive then the M3's
Thanks!
1995 325i - Sold
1997 540i/6 - Wrecked
1998 328is M/pkg, Born and raised in Germany - Sold to a Max member
2000 540i/6 - Sold
JvzwetE36325 is offline   Reply With Quote
Old 09-22-2010, 12:04 PM   #2
Who's the shop that will do it without a profile?
Old 09-22-2010, 12:54 PM   #3
MarkD
MarkD's Avatar
Some shop that has a lot of spare time.. best to just find some used s50 cams.
Old 09-22-2010, 07:39 PM   #4
sb_600
sb_600's Avatar
I'm also looking to have my intake cam ground, but with a profile - I don't have any options for cams since i have an M50 non-vanos. I do have 2 intake cams, so I only need to grind one (the other will go on the exhaust side). Any help would be appreciated!
Shawn
Old 09-22-2010, 09:02 PM   #5
MarkD
MarkD's Avatar
If you want a chillcast blank ground, call Paul Burke in the USA. I can supply his contact info if anyone wants it.
Or just read this thread:
http://forums.bimmerforums.com/forum...php?p=20353460
Old 09-22-2010, 09:51 PM   #6
sb_600
sb_600's Avatar
Thanks Mark. I'll send him a message. I'm looking at low budget options for now - just regrinding my cam as opposed to buying a new one, but I'll see what he can do.
Shawn
