Old 09-15-2010, 07:57 PM   #1
SamE30e
SamE30e's Avatar
M50 bogging problems
Hey,
So my car is being weird. I went to get an emission test and it went 3 times the limit, it's running rich, I know that. Hc limit is 680, my car ran 2800.
Also, the odd time I goto start from a stop, the car bogs and hesitates, then after the RPM's get up it's fine, but still sleightly boggy.
I got a MAF code, I put a new one in and it's still doing it, I changed the Dinan ECU out and put a stock 403 in and it did nothing.
Is it possible for the car to be stuck in cold start? Coolant temp sensor, maybe IAT sensor? My other guess was the FPR.
Sam
Edit: Stomp test says 1444 (No code) also brand new car, brand new o2.
85 325 - Turbo M52B28.
Old 09-30-2010, 10:41 AM   #2
EURO_TRASH
EURO_TRASH's Avatar
Mine ahd the same issue i changed the maf sensor and did nothing to fix the issue, i had checked all the vac lines and i also changes the cam position sensor same issue didnt fix the problem, so i dug deeper and it was a broken wire in the maf sensor plug check yours out and see my car runs like a dream now
EURO_TRASH is offline   Reply With Quote
Old 09-30-2010, 03:20 PM   #3
El Gato Liso
El Gato Liso's Avatar
sam my car is doing the exact same thing.
cold start it feels dumb until rpms are high. only solution i have is to a) drive wiht a heavy foot until its warm enough b)let it warm up
R.I.P. E30
Old 09-30-2010, 03:43 PM   #4
BigD
the misanthropist
BigD's Avatar
Check your ignition system (coils, spark plugs).
