Old 09-13-2010, 12:35 PM   #1
blastedM3
Jane & Finch
blastedM3's Avatar
Exclamation key turns loosely in the ignition
Im having abit of a problem with my ignition.
The lights are all on on the dash but when i turn the key it turns freely without any effect on the car. The steering does not lock nor does the lights turn off when i take the key out.
It wont start or turn the lights off. It happened when the car was on and when i tried turning it off, they key just turned back with no affect. I had to turn the car off manually by pulling out the fuse.
what could the problem be? Any input is appreciated.
thanks
1997 E36 M3-Sold
1991 318ci-Project Car-Almost Done
93 Honda HB-Daily Beater
blastedM3 is offline   Reply With Quote
Old 09-15-2010, 03:42 PM   #2
The ignition switch cylinder is busted. Common E38 problem.
You have an E38 right? If so, browse over to www.E38.org and there is a write-up of how to fix this issue. (CTRL+F is your best friend on that site)
Old 09-15-2010, 09:48 PM   #3
craigIS
A.K.A. crossfire291
craigIS's Avatar
Sounds like the ignition switch. Thought mine was toasted a couple days ago. Luckily it wasn't.
flickr
