Old 09-20-2010, 05:01 PM   #46
richie_s999
Originally Posted by iverson03tj View Post
I heard that performance clutch n LTW flywheels does help transfer the power to the tranny, and if ur really extreme... doesnt a carbonfibre driveshaft help too.... Also thats alot of hp u got from those mods... are the s50 cams easier to instal than s52? and why did u use s50 cams, instead of s52?.. just wondering... my next mods for the winter will be the m50 mani n s52 cams.. and markd software.
Lightend drive line helps, more so on dyno then on track, if things are too light you don't get the twist snap of the torque and lose speed when u hit it.
Lighter wheels help more
Old 09-20-2010, 06:53 PM   #47
SiR
Vtec just kicked in
General maintainence.. my dads m3 cost alot more in parts... for example... oil change in mine is about 65 bucks using mobil 1 5w-30, he uses european syn oil.. n pays 120 bucks for the oil change...
Also there are many 328's that have close to the m3 hp. Check on bimmer forums..
http://forums.bimmerforums.com/forum...d.php?t=478545
And also i think the i seen on that thread is like 227 rwhp... roughly..
that all depends on what oil you use.
he doesnt need to spend $120 on oil. lol.(unless you are refrencing an e46 m3 which is a completely different beast than the e36 m3. the e46 certainly costs more)
I spent $50 for the oil on my last change, and its great oil to.
Im not saying mods dont add anything to a 328. dont mis interpret what I am saying. fact is you cant turn your 328 into an M even if you think the US spec is not a "True m".This argument is not just bmw specific either...
doogee(Sp) turned out some great numbers for his mods but the same mods to an M would make more power + the other things to the m(like subframe reinforcements which come stock ,lsd etc etc). There is a lot of things to buy afterwards to change out or add that you couldve just had from the start.
That doesnt mean a 328 is no good(and I am not saying that at all). I test drove both(Even one with similar mods to doogee) and preferred the M by quite a bit. It was a no brainer for me.Both cars have similar issues to watch out for.
part prices are the same too. just check online.
and theres not much(if anything) you can do to overcome driveline loss. As I said I think the 328 is a great choice for the op.
at the end of the day both motors are a bit silly to try and make big n/a power on.
Have you run down the 1/4 with those mods doogee?
-||Old Crayons||-
Old 09-21-2010, 02:01 AM   #48
JUICY J CAN'T
propr'one's Avatar
^^actually, you can turn a 328 into an m3. Swap the interior, exterior, suspension, driveline and brakes, and its an M3. You could re-vin it an M3, and assuming you did it perfectly, no one would ever know.
hid headlights
Old 09-21-2010, 02:07 AM   #49
doogee
Stance is Gay.
doogee's Avatar
Very true.
My 328 is a pretty good example. E36's are like Lego's compared to E30s, E46 etc.
Dakar M3 Track Build Thread
Old 11-30-2010, 07:49 AM   #50
rightnwrong
My e34 is working for 15years until. He is tough.
rightnwrong is offline   Reply With Quote
Old 12-04-2010, 03:53 AM   #51
iverson03tj
I like my 328 so much, im swapping it into a m3 shell
e30 325ic -
PREVIOUS CARS
'01 Audi A4 B5
'96 Civic B16
'95 Acura Legend Type II
'97 Euro Estroil E36 M3 Vert
