Go Back   maXbimmer Forums > Platinum maXbimmer Sponsors > Bimmersport Automotive
Old 09-09-2010, 04:57 PM   #1
Jon@Bimmersport
Jon@Bimmersport's Avatar
Targa Newfoundland & Bimmersport Automotive
Hello board,
As some of you noticed when you came by...there was an E30 M3 shell in our shop that was getting an extensive build. The purpose as I explained to some is for the 2010 Targa Newfoundland race (http://www.targanewfoundland.com). The drivers some of you know (Herb Wong "MGYVER" and Desmond Sie from BMW Toronto) competed in the last competition with an E34 M5. This year...they have built a solid E30 M3.
Check out the mod list and pics...the pics speak for themselves and the extent of work involved in this beautiful machine.
Mod list (very extensive)
Driveline
3.2L S50B32 engine
Active Autowerke Alpha-N Tune
AKG Group N polyurethane engine mounts
E36 M3 5-speed ZF transmission
UUC Evo 3 shortshift kit
UUC Double shear selector rod (DSSR)
UUC Stage 2 Lightened 8.5lb flywheel
E34 M5 clutch
E30 M3 driveshaft
3.25LSD differential
Fluidyne all aluminum high performance radiator
Mishimoto electric cooling fan
Setrab oil cooler
Walbro 255lph fuel pump
Brakes, Wheels and Tires
Massive Brakes “Rally” big brake kit with:
Wilwood 6-piston SL-6R radial mounted calipers and
300mm x 32mm slotted rotors
Wilwood H compound brake pads
Manual brake conversion with:
Tilton Series 600 firewall mounted pedal set
Tilton Series 75 master brake and clutch cylinders
VAC Motorsports custom firewall mounting plate
Goodridge stainless steel brake lines
Kosei K1 15x8 wheels
Toyo R1R 225/45 R15 tires
Suspension
Hotbits DT-1 suspension with adjustable dampening, external canisters, and custom rally valving
Hotbits adjustable camber plates
Ireland Engineering urethane subframe bushings
Treehouse Racing “eyeball arms” for control arm bushings
Exhaust
Custom stainless steel Supersprint exhaust
Exterior
BMW Alpine white paint with custom M-Stripes
DTM style side mirrors
Interior and Safety
O’Brien Motorsports custom roll cage with A-pillar gussets, X-brace door gussets, and differential mount
Custom aluminum co-driver foot rest and aluminum pacebook holder
MCAL custom flocked dash
VAC Motorsports Aluminum floor pans
VAC Motorsports seat mounts
Sparco Evo 2 seats
G-Force 5-point camlock racing harnesses
ESS Fire-suppression system
E30 Motor Werks severe duty skid plate
Electrical
Speedwire Systems custom switch panel and relay panel
BMP racing cluster and gauge pod
VDO X-Treme Pro Eliminator memory tachometer with programmable shift light
Speedhut custom programmable speedometer
VDO Cockpit series oil pressure, oil temperature, water temp, voltmeter, and fuel gauge
HID retrofit with E46 projectors and Hella ballasts
Terratrip 303 Plus rally computer with remote driver display
Peltor intercom and in helmet noise cancelling headsets
ChaseCam in-car video recorder
Diamond in the rough..
Cage/Interior:
Authorized Ontario dealer for Active Autowerke|VF-Engineering|AFE|Bilstein Suspension|H&R Suspension|KW suspension|Brembo Brake Systems| Stoptech| - Call us for the best pricing
Old 09-09-2010, 04:59 PM   #2
Jon@Bimmersport
During paint:
Final product w/ the drivers:
Thank you Herb and Desmond for choosing BimmersportAutomotive to build your race car!
Old 09-09-2010, 06:21 PM   #3
Steve30
Techno Viking
Steve30's Avatar
wow cool, I didn't know Desmond was into this kind of stuff. He helped me out when I took my car to the dealer for a new clutch
E36 ///M3 S54
???whp E30 coming soon.
Old 09-09-2010, 06:54 PM   #4
e30_kid89
The Afro-stig
e30_kid89's Avatar
You missed/skipped a CRUCIAL part of this cars build...the vinyl application by Mr.Rudy Glarner!!
Old 09-09-2010, 08:28 PM   #5
SamE30e
SamE30e's Avatar
Eff yes!
91 318is - M50NV (gone)
85 - 325
Old 09-09-2010, 11:20 PM   #6
Jon@Bimmersport
Just for you Devon
Old 09-10-2010, 06:58 AM   #7
tominizer
Cool. Nice to see an E30 M3 restored to do what it was meant to do........... be awesome !!!! Only thing better would have been a built S14 instead............ but that's money.
Old 09-10-2010, 10:27 AM   #8
King Luis
The King.
King Luis's Avatar
i love watching the rally. always wanted to be in it. best of luck guys.
2004 Silver Gray M3
Old 09-10-2010, 10:46 AM   #9
pawcio
pawcio's Avatar
It looks very very cool. Rallying is my favourite motor sport. Good Luck!!
__
Old 09-13-2010, 02:13 PM   #10
Jon@Bimmersport
Hey guys here is a link to their blog that will be updated.
http://targabmwm3.blogspot.com/
Old 09-13-2010, 02:13 PM   #11
Jon@Bimmersport
