Old 09-06-2010, 04:30 PM   #1
matty.dc
matty.dc's Avatar
E30 m20 misfire
Update: Compression is good, timing is redone, impulse wire replaced, broken vacuum line to fpr fixed. The car is still missing at idle and throughout driving range. I changed afm's to see if it made a difference, but nothing.
Any ideas????? CPS??? Clogged injectors maybe ????
Matt
2013 Ford Edge - Daily Driver
Old 09-06-2010, 04:43 PM   #2
Ceeker
carbon build up on the valves maybe.
1 90 325is white - keepin
1 87 325i vert -red - keepin
KEEPER 88 5sp Vert 2016
Old 09-06-2010, 05:07 PM   #3
Pull each plug wire individually to see which cylinder is misfiring. If you find it, it will not sound any different. You could then try swapping plug wires around, pulling plugs and examining them, etc.
If you suspect carbon or fouled injectors, try running Seafoam through it. (The product, not the foamy pollution on Lake Ontario.)
I'd really focus on finding the offending cylinder, and examine the plugs. You will see if its missing fuel or spark that way, narrowing the troubleshooting process significantly.
Old 09-06-2010, 08:09 PM   #4
matty.dc
matty.dc's Avatar
cylinder 4 is the culprit, i checked spark before and it was good.
Old 09-06-2010, 08:27 PM   #5
Ceeker
Where does one get this "seafoam?" I need to decarbon my car.
Old 09-06-2010, 09:08 PM   #6
Napa carries it. Amazing stuff.
So you know its cylinder 4? Switch wires from 3 and 4 and see if the miss is still in 4. Then you've narrowed it to either the plug, injector or cylinder.
Change the plug, run seafoam or pull the injectors and have them ultrasonically cleaned, test compression / leak down on cylinder 4.
Old 09-07-2010, 01:09 AM   #7
iignite
just under load? or when you're idling as well?
iignite is offline   Reply With Quote
Old 09-07-2010, 03:01 AM   #8
voluted
voluted's Avatar
When I first got my car it had been sitting in a driveway for around 6 years. The gas that was drained from it was brown and was filled with particles. I didn't think much of it at the time (new to cars) and cleaned the tank as best I could then filled it with gas and drove it for almost a year before my injectors were filled with extremely fine rust particles from the gas tank. If you suspect a fouled injector, take the pump out and look in the tank with a flashlight. If theres crap swimming around at the bottom there is a good possibility that some made it's way past the sock filter and the external fuel filter and clogged the filter in the injector.
My car was running on 3 cylinders much like yours is now and it happened within minutes it seemed. Although I wasn't getting white smoke from my exhaust. Different motor though (M42 then).
Old 09-07-2010, 03:56 PM   #9
matty.dc
matty.dc's Avatar
the white smoke is cured it was a broken vacuum line to the fpr.... and the car misses at all ranges and idle.
Old 09-07-2010, 06:04 PM   #10
hosty
hosty's Avatar
m50 swap? lol
hosty is offline   Reply With Quote
Old 09-07-2010, 08:27 PM   #11
matty.dc
matty.dc's Avatar
haha ill go big or go home on that issue 5.0
Old 09-07-2010, 08:44 PM   #12
MarkD
MarkD's Avatar
Some people may not follow that you mean swap the complete wire from the distributor cap to the spark plug. Thay may think it means swap wires from 3 and 4 at the spark plug end only.
Old 09-07-2010, 10:00 PM   #13
matty.dc
matty.dc's Avatar
i changed the wire totally and same problem....could it be a bad motronic unit?
Old 09-07-2010, 10:31 PM   #14
matty.dc
matty.dc's Avatar
it threw a code 1222 when i did the stomp test.
Old 09-07-2010, 11:57 PM   #15
Nick_V
Nick_V's Avatar
1222 means the DME senses a rich or lean condition for more than 10 seconds. If I'm reading correctly, you've isolated the problem to cylinder 4, verified that there's spark, and have good compression across the board. The only thing that really leaves is the injector or the electrical connection to it, I think.
That code is a bitch. I just got rid of it on my M42 after lots of trial-and-error. Turned out to be the FPR.
