Old 09-01-2010, 07:54 PM   #1
heretic
coolant / heating issues
1995 325i
New fan clutch, water pump, thermostat, upper and lower rad hoses, rad pressure washed.
I KNOW there is some air in circuit and I keep trying to bleed it out.
When driving temp stays at 12 o'clock (medium) then will occasionally climb and sometimes hit red, then the temp drops (I replaced the thermostat).
Other issue is that heat is very sporadic when the heat is on full.
My thoughts are:
1) partially blocked heater core
2) heater valves malfunctioning
3) air in the circuit is causing all the problems
Any advice ?
I'm thinking of draining all fluid, removing hoses to heater core and flushing that seperately, do the heater valve cleaning, refill and bleed.
heretic is offline   Reply With Quote
Old 09-02-2010, 03:16 PM   #2
heretic
update #1; Heater valves click when power applied and are receiving power.
Expansion cap has "leak" so switched it with other car.
Worst case scenario could be head gasket.
Old 09-02-2010, 06:16 PM   #3
Daneee
be cool
Daneee's Avatar
Send a message via MSN to Daneee
if the water pump new and still over heating = head gasket!!!!
suck the fish
Daneee is offline   Reply With Quote
Old 09-03-2010, 12:22 AM   #4
blastedM3
Jane & Finch
blastedM3's Avatar
it could be a faulty thermostat. Take it out and see if it still overheats. if it still does than its ur headgasket.
1997 E36 M3-Sold
1991 318ci-Project Car-Almost Done
93 Honda HB-Daily Beater
blastedM3 is offline   Reply With Quote
Old 09-03-2010, 05:17 PM   #5
heretic
and the winner is:: head gasket
Old 09-03-2010, 05:53 PM   #6
Ceeker
oh boy oh joy oh bliss..lol
1 90 325is white - keepin
1 87 325i vert -red - keepin
KEEPER 88 5sp Vert 2016
