Old 09-01-2010, 11:23 AM   #1
Finch
1992 BMW 325i M50
Alright so I bought a 92 E36 at the begining of the summer. The car was running strong when I got it, than I found out it was leaking coolant into the oil. SO I bought a used M50 from Filip in Milton swapped it into the car and have not been able to get it running now. I know the motor is good, my issue is that there is no spark going to the coil packs. I have put an OEM replacment clutch kit in, had flywheel machined, i bought a set of 15 inch bbs rims, a set of winter tires mounted on steel rims, plus it has the origional 325 aluminum rims still. The car itself has 212000 on it. It's silver, a 5 speed, I had brakes put on all around new abs sensors, abs control valve, brake master cycl. I put about 2500 just to get this car saftied,I had the car saftied at the begining of the summer and it passed no problem once that work was done. The car also comes with the origianal M50 motor as well(Ran until the day I pulled it out) Check out my worklog for some pictures of the car! If anyone is interested just PM me, Im not even sure how much to ask for this car without loosing a ton of money.
1992 BMW 325I - Worklog: http://www.maxbimmer.com/forums/show...45#post1432645
1996 Mazda MX-3 - Worklog: http://www.mx-3.com/phpBB3/viewtopic...548512#p548512
Finch is offline   Reply With Quote
Old 09-01-2010, 01:13 PM   #2
ChiGz
Why not just post the price?
ChiGz is offline   Reply With Quote
Old 09-01-2010, 06:57 PM   #3
Finch
If I could get 3 grand for everything I could cut my loss's. I would still be loosing about 2 grand after all the work and parts put into it.
Old 09-02-2010, 11:58 PM   #4
Finch
$2500 With everything
Just swapped in M50 with approx 200xxx
Machined Flywheel/New OEM Clutch kit
Original M50 motor (leaks coolant into oil)
15 inch BBS 5 series rims
Original BMW 325 Rims
All season Summer Tires
Winter Tires
Pioneer Deck
212k on body
New Pads/Rotors all around
New Brake Master Cyl
Used ABS control Valve
The car is SO close to being done, I just cant figure out why no spark will go to the coil packs. That is hounestly the only thing stopping me from driving it. I had this car safetied back in june.
Old 09-03-2010, 12:17 AM   #5
Finch
Check out my Kijiji Ad, there are a few more pictures on there!
http://toronto.kijiji.ca/c-cars-vehi...AdIdZ227646087
