Old 01-26-2011, 08:37 PM   #16
BiBimBap
BiBimBap's Avatar
I had the same problem and it turned out to be a short in the vanos sensor. Good thing it was under warranty because it would have been a $700 fix.
BiBimBap is offline   Reply With Quote
Old 01-27-2011, 03:01 PM   #17
2009323i
Thanks for the info. I will run it by them. How did they find out that it was the vanos sensor?? what car do u have?
2009323i is offline   Reply With Quote
Old 01-28-2011, 02:31 PM   #18
BiBimBap
BiBimBap's Avatar
I have a '06 325i.
I had them check out the rough idle problem and the tech found a error code of some sort. Apparently he had to take apart the head, re-install new wiring harness portions and sensor - and then put it back together..along with new oil and seals and such.
Took a few days to get it done.
Good luck with yours!
Old 05-06-2011, 06:34 PM   #19
eckert014
i had this problem and got it fixed at the dealership. it was throwin faults tho. anyways it turned out to be an eccentric shaft sensor that had to be replaced
eckert014 is offline   Reply With Quote
