Old 08-17-2010, 06:56 PM   #1
doogee
doogee's Avatar
S50 cams in 328is help
I got my hands on some s50 cams and trays. I'm going to have them installed in my M52.
Now I'm not sure if I can use my m52 trays or what not. I've searched and no one seems to have a dead answer.
Can someone please give me a straight answer on what it takes to install these?
Please let me know.
Dakar M3 Track Build Thread
Old 08-17-2010, 09:15 PM   #2
e30_kid89
The Afro-stig
e30_kid89's Avatar
I believe you have to use either the m50(except non-vanos) or s50 trays along with the cams you have. But I'm not 100% sure, maybe 91% lol...From what i remember you can use only m52 or s52 trays with the s52 cams and the same for the m50 or s50 trays with s50 cams.
Old 08-17-2010, 10:50 PM   #3
Dissembler
Dissembler's Avatar
+1 you need the m3 cams, trays and bearing caps. Also, i don't think you can install s50 cams into and m52 at all or s52 cams into an m50. S50 goes into m50 and s52 goes into m52.
better double check which ones you got.
S52 E30
Old 08-18-2010, 03:32 AM   #4
doogee
doogee's Avatar
I have S50 cams with S50 trays. Should work. I also have the S50 bearing caps.
It doesn't make a lot of sense thats S50 cams will ONLY work in an M50 because the heads are all the same. Minus the trays.
Old 08-18-2010, 12:38 PM   #5
ScotcH
M52, s50, s52 are all the same trays. The m50 is different. You'll be fine with either the s50 or the m52 trays, but I would stick with the trays and caps that came with the cams if they are in good shape since the bearing ledges will be mated to the cams.
The s50 cams will work perfectly fine in an m52. The only time there are issues is if you are trying to install into an m50 ... there you need the m52/s50/s52 trays.
Old 08-19-2010, 01:29 AM   #6
doogee
doogee's Avatar
^^ Thanks man you are correct.
The S50 cams dropped right in!
Old 11-16-2010, 06:51 PM   #7
EURO_TRASH
EURO_TRASH's Avatar
hey is there a reason why you went with the s50 cams and not the s52 cams?
EURO_TRASH is offline   Reply With Quote
Old 11-16-2010, 10:45 PM   #8
doogee
doogee's Avatar
Nope
