Old 08-12-2010, 11:17 PM   #16
Originally Posted by tig View Post
had similiar problems in the past on my e36, changed the MAF and it went away
I'm not sure how that could be any more irrelevant.
Old 08-13-2010, 01:28 AM   #17
325isStephen
Drifter
Originally Posted by MarkD View Post
It could be a bad crank sensor.
If the crank sensor was bad wouldn't the fuel pump not kick on? I had an e36 with a bad crank sensor that was diagnosed by another shop as a fuel pump. I then determined the pump was not coming on and I had no spark and checked the crank sensor.
Maybe its different on the e30, but It wouldn't make sense to me.
Old 08-13-2010, 06:34 AM   #18
El Gato Liso
El Gato Liso's Avatar
is your battery good.
R.I.P. E30
Old 08-13-2010, 06:55 AM   #19
bmw-dinan36
bmw-dinan36's Avatar
From my experience engine cutting out is due to either sensors, ignition. Or fuel pump\ sending unit if not then electrical?. Goodluck.
BMW... Brings Me Women and Breaks My Wallet.
1992 325i -winter-
2001 330ci -Summer-
bmw-dinan36 is offline   Reply With Quote
Old 08-20-2010, 10:04 AM   #20
Dissembler
Dissembler's Avatar
well, knock on wood but the problem hasn't returned.
I think it was a combination fuel pump relay and, more likely, the actual connector on the fuel pump itself.
I noticed the connector on the fuel pump made solid contact, but it came off pretty easy. When I cranked the car, I didn't always hear the fuel pump running. Then whenever I put the access panel back on, the connector would back off and car would not start.
My solution was to ziptie the connector to the output fuel line therfore holding it nice and tight, as well as cleaning the contacts. I also replaced the fuel pump relay (had a new one lying around) and will still be picking up a main relay as extra insurance
S52 E30
