Old 04-11-2010, 07:54 PM   #1
SamE30e
SamE30e's Avatar
DRL Removal: The proper way (for off-road use)
I'm not responsible for you frying your wiring or anything of that sort, if this is illegal in your place of residence, do at your own risk.
Well after much searching and finding nothing I tried to tackle the DRL removal. I heard you needed to add a relay, run wires, change relays etc etc. I tried this and fried my fusebox, which actually led me and a buddy to figure out what I hadn't found before.. The proper way to do it, and find out how BMW enables them.
The relays use a switched ground to complete the coil circuit in the relays. If you took a test light, hooked it up to 12v and started poking around the headlight switch you'd find switched grounds. One in particular is used for completing the low beam and highbeam relay circuit. Shown below.
If you follow that wire, it goes through the firewall and ends up in the fusebox connected to nothing, BMW actually put a male connector on the end of it because in non DRL cars it's plugged into the relay terminal 86. But in DRL cars it's sitting in the fusebox covered in heatshrink shown below (I had cut the shrink away at this point)
To remove your fusebox: disconnect your battery and turn the key forward to remove and surface charge.
Remove your fusebox cover
Remove the 3 screws holding the 2 pieces together (1 on the inside by the fender, and 2 inside the box. You may need to remove a relay to get to one of the screws.) Don't remove the allen head bolt, that connects all the power to the fuses and is a pain in the ass to get the nut on the other side back together.
Carefully seperate the 2 pieces and locate the wire.
If you do look at your #86 terminal and follow the red wire, you'll see that it comes off and runs out of the fuse box and is attached to the hood latch with a ring terminal.
What you want to do is take that terminal off, pull the wire back into the fuse box and connect the yellow and green wire, to the red wire that I just mentioned.
To re assemble your fuse box, do the reverse of taking it apart.
If all goes well your headlight switch should work like: position 1, all off. position 2, parking lights and interior lights. Position 3, headlights, parking lights and interior lights.
Sam
91 318is - M50NV (gone)
85 - 325
Old 04-11-2010, 08:08 PM   #2
Well DONE Sam, excellent work. A lot of people have been looking for this for years!!
Old 04-11-2010, 08:24 PM   #3
SamE30e
SamE30e's Avatar
And on top of all this I figured out why my horn didn't work. lol
85 - 325
Old 04-14-2010, 03:44 AM   #4
JUICY J CAN'T
propr'one's Avatar
I guess canadian spec cars are different, my 90 us spec functions like this stock.
hid headlights
Old 04-14-2010, 07:23 AM   #5
BMW BMXer
Wants a 350 Blazer.
BMW BMXer's Avatar
I dunno what year DRLs came in but my us car didn't have them either.
Stanceiseverything.com
BMW BMXer is online now   Reply With Quote
Old 04-14-2010, 07:39 AM   #6
very very kewl!!! thanks Sam!!
2 IX's -sold and parts
2 325i 4 dr - sold
1 87 325is red - parts
1 89 325i vert grey - parts
Old 04-14-2010, 09:40 AM   #7
gervs
gervs's Avatar
US spec cars didn't get DRL till 95 and up, I don't even think they to this day have a mandate for them. My 95 e36 florida car had no drl
gervs is offline   Reply With Quote
Old 04-14-2010, 11:45 AM   #8
SamE30e
SamE30e's Avatar
US car's don't have DRL's. Only Canadian. So this only applies to Canadian cars.
85 - 325
Old 04-14-2010, 07:59 PM   #9
davericher20
black and blue
davericher20's Avatar
I didn't know this was an issue excuse my ignorance.
Mine does this already. What was the problem with canadian cars? And what is DRL? (Daytime running lights?)
1989 325 IX Touring
Old 04-14-2010, 08:02 PM   #10
Nick_V
Nick_V's Avatar
^no problem - federal gov't regulation.
Old 04-15-2010, 01:24 AM   #11
SamE30e
SamE30e's Avatar
Whenever the ignition is on your lowbeams are on. You can't turn them off.
85 - 325
Old 07-31-2010, 01:27 PM   #12
Berlin
hey
my green/yellow wire runs up into some fuse and the red wire with the ring sits alongside with a fatter red wire both attached to the nut/shcs on the back...but i still have drl's...what could this mean?
Berlin is offline   Reply With Quote
Old 07-31-2010, 08:34 PM   #13
iignite
probably means that its a pain in the ass to turn off drl's. Ive been trying to figure out how to turn it off for a while..
iignite is offline   Reply With Quote
Old 08-03-2010, 02:10 PM   #14
Hasselhoff
Hasselhoff's Avatar
Ok, I've been trying to resolve a potentially related issue with the lights in my 90 325... Here's the deal: Key on, Headlight switch off - front low beams on (which I now understand is normal. Switch in position 2 - running lights on, low beams off. Switch in position 3, low beams and fogs come on, but running lights (and dash lights), go out.
Any advice on where to concentrate my search for the root cause would be much appreciated!!
Hasselhoff is offline   Reply With Quote
Old 08-03-2010, 02:59 PM   #15
HavocSteve
Wouldn't the schematics of a 87' 325 be somewhat the same for a 90' 325? You could probably just cross-reference both plans and determine which wires need to be switched. I know everything is off in position 1 on my 87'.
