Old 08-01-2010, 05:21 PM   #1
voluted
voluted's Avatar
Post FS: 413 red label ecu, 3.5" MAF, e36 pink injectors e36 metal water pump & thermostat
I am selling the following working used parts:
BOSCH 413 red label DME - $120
Aftermarket 3.5" 540i MAF (Bosch #0 280 217 800) - $80
21.5# s52/m52 pink injectors (Part #280150440) x6 - $40
Metal impeller water pump - $40
Wahler 88c thermostat - $10
Don't hesitate to ask for more information about any of these items.
Thanks for looking!
Old 08-03-2010, 12:08 PM   #2
voluted
voluted's Avatar
bump
Old 08-03-2010, 12:31 PM   #3
iverson03tj
iverson03tj's Avatar
is the 3.5 maf a direct fit, will i need to do anything else..
Old 08-03-2010, 03:53 PM   #4
voluted
voluted's Avatar
For 540i's and 740is sure, but for an E36 i'm pretty sure you need to expand the stock intake boot or get a new one. You would also need updated engine software for it to work properly.
Old 08-04-2010, 04:45 AM   #5
iverson03tj
do i have to expand the boot both before and after the maf.... and will ti run fine with the e36.... im planing to get a software done by november...would it do anything bad to my engine till november...
Old 08-04-2010, 03:20 PM   #6
SiR
Vtec just kicked in
dont put the bigger maf on without the software change.
if you buy it. just put in on your desk until november
-||Old Crayons||-
Old 08-04-2010, 03:30 PM   #7
MarkD
MarkD's Avatar
I thought I heard someone mentioning software so here I am!
Yes just keep that bigger MAF stored away till you come to me for software.
A bigger MAF is not really required unless you use bigger cams and get the airflow up, a stock one will work fine otherwise.
Old 08-04-2010, 03:41 PM   #8
M52pwrdTi
are the pintle caps on the injectors in good shape? how many miles?
M52pwrdTi is offline   Reply With Quote
Old 08-04-2010, 03:55 PM   #9
voluted
voluted's Avatar
Each of the injectors has 1 or 2 broken fins. If i recall correctly, the car had about 230,000 kms on it and was running fine when they were pulled. The car was an accident write off.
Old 08-04-2010, 05:04 PM   #10
blk325i
blk325i's Avatar
is the 413 chipped for the 3.5?
blk325i is offline   Reply With Quote
Old 08-04-2010, 09:01 PM   #11
voluted
voluted's Avatar
Nope, the ECU has never been opened and was from a 1993 325i 4 door.
Old 08-06-2010, 11:08 PM   #12
voluted
voluted's Avatar
Bump, make me some offers!
Old 08-10-2010, 11:35 AM   #13
voluted
voluted's Avatar
bump
Old 10-07-2010, 03:18 PM   #14
sb_600
sb_600's Avatar
pm sent
Shawn
Old 10-16-2010, 07:34 PM   #15
voluted
voluted's Avatar
ECU, MAF, and water pump sold.
