Old 07-29-2010, 11:29 PM   #1
kical
problem with e90
hey
I installed today new wheels on my e90 and after couple kilometers my computer showed that there is a problem with tires (now enough air or pressure).Ichecked any ale 4 wheels have the same pressure and everything looks ok with them.Is there any way to reset this error?
Is it possible because tires are low profile 235x35 and 265x30 or rims are staggered?
thanks
mike
kical is offline   Reply With Quote
Old 07-30-2010, 04:15 PM   #2
bmw335i
bmw335i's Avatar
Send a message via MSN to bmw335i
yes.. scroll through the menu on the button on the left of ths steering wheel and scroll down until you see 'reset"
bmw335i is offline   Reply With Quote
Old 07-30-2010, 05:19 PM   #3
kical
i tried to reset it but it's still showing the error
Old 07-30-2010, 08:58 PM   #4
bmw335i
bmw335i's Avatar
are u running RFT?
Old 07-30-2010, 11:33 PM   #5
kical
yes,i run on falken fk 452 235x35x19 and 265x30x19
Old 08-04-2010, 09:31 AM   #6
bmw335i
bmw335i's Avatar
hm.. resetting should do the trick.. I had the same issue.. tried resetting it and it came back..did the water trick and found a nail in one of my tire.... are you sure you don't have a nail in one or more of your tires?
Old 09-26-2010, 02:50 PM   #7
cheeba23
You need to find the reset ... push quickly once ... then hold down for approx 5 sec
It will reset already done it twice on mine
cheeba23 is offline   Reply With Quote
Old 10-17-2010, 05:11 PM   #8
martinM5
do the new wheels have TPMS sensors installed??? if not resetting it will not solve the problem-you must disable to the TPMS system- or install BMW tpms sensors than reset-
2009 BMW 335i Coupe Msport LeMans Blue on Sexy Saddle
2016 X3 28d Msport SpaceGrey on Saddle
martinM5 is offline   Reply With Quote
Old 10-17-2010, 09:10 PM   #9
BmW1819
bang on different size rims/ tires will trigger this tire pressure monitor do what cheeba said that will fix your problem there are no tpm monitors in e90's they don't have that anymore
Old 10-18-2010, 09:30 AM   #10
ScotcH
They never had them (e46 uses wheel speed sensors).
Old 10-18-2010, 02:01 PM   #11
King Luis
The King.
King Luis's Avatar
correct, bmw always used wheel speed sensors and never had sensors on the wheels.
also, the falken 452's are not run flat tires even though that has nothing to do with it.
make sure your tires are correctly balanced and they all have the same psi (or around the same psi) and run the tire pressure reset properly. read the manual. my dad has an e90 and the manual tells you exactly how to do it.
Mods: TBD.
Sold:2004 Silver Gray M3
Gone:1990 Brilliantrot 325is
