Old 07-26-2010, 11:04 PM   #1
drivetolive
drivetolive's Avatar
Aftermarket vs OEM Clutch Fans
So I had my clutch fan replaced with an aftermarket one a couple of months ago and the dam thing won't turn off (very annoying). It's on all the time, makes my car sound like a big rig. Even when I start it (cold start) it comes on full blast and than gradualy slows down as my car warms up. But regardless of whether my engine is hot or cold, I could hear the fan (it's really loud).
On a cold night, it's not as loud but still noticable. On a hot summer day (like today) it's on full blast.
My friend's exact same car doesn't have the same "problem".
I've had some people say it's not normal, others say it's normal, while others say it's happening because it's an aftermarket clutch fan.
I've asked numerous people and can't really get a clear cut answer. Would replacing it with an OEM clutch fan prevent it from being on all the time? Want to make sure before I shell out the $300 for an OEM one.
drivetolive is offline   Reply With Quote
Old 07-26-2010, 11:49 PM   #2
zarbat007
What brand is it?
zarbat007 is offline   Reply With Quote
Old 07-27-2010, 12:25 AM   #3
///Mmm
Need an s85!
The OEM fan clutch should only engage when the engine temp gets high ,usually in traffic or a really hot day.
The way your current fan clutch is acting is not normal, i suggest you change it.
Call any of the sponsor shops, they should confirm this.
///Mmm is offline   Reply With Quote
Old 07-27-2010, 01:09 AM   #4
Eurostyle
Eurostyle's Avatar
Yes, not normal at all! Take it off before it fully locks up and BAD things happen! (trust me on that, too many horror stories!). If you dont want to spend that much, i have an almost new OEM one, for fraction of the price!
Eurostyle is offline   Reply With Quote
Old 07-27-2010, 01:34 AM   #5
drivetolive
So getting an OEM one would surely fix it? Or do you guys think my engine temp is getting too high causing the clutch fan to come on? B/c whenever I get off the highway I notice that it's off when I accelerate from an off-ramp, but after a minute or 2 of city driving it comes on.
Hey eurostyle, thanks for the offer, if you don't mind PM me a price and I could probably drop by tomorrow .
Thanks for the help guys, keep it coming.
Old 07-27-2010, 01:52 AM   #6
drivetolive
BTW sorry, don't know what brand it is.
Old 07-27-2010, 08:43 AM   #7
Dr. Flyview
Formerly Flav_cool
Dr. Flyview's Avatar
Send a message via MSN to Dr. Flyview
The way I understood it, the actual engine fan doesen't change speeds. It's always spinning at a medium rate. That's why there's a mechanical clutch which doesn't allow it to spin up to the engine's revs (too tight), but also doesn't let it stop spinning (too loose).
There is ANOTHER electrical engine fan (auxiliary fan). This one has 3 speeds: off, low, and high. If you have a mechanical clutch fan (above), you should really only hear this come on at idle when there's little airflow into the rad. It is controlled by a temperature switch that goes into the radiator. Perhaps if this is the aftermarket one you're talking about, it's no longer connected to this switch, or doesn't correctly interpret the readings.
BTW you don't want a fan to be too fast or on when it's not supposed to be, since you may run the engine too cold.
1998 BMW 328is - summer
1994 BMW 325i - daily
1992 BMW 325i - totaled
sold
Old 07-27-2010, 07:13 PM   #8
drivetolive
Sorry forgot to mention (and I'm sure this makes a difference), when sitting idle at a red light for example, I can't hear the fan (obviously), it's only when I begin to accelerate I could hear the thing come on and get louder (it matches my engine rpms, the higher the rpms the louder the fan).
When my hood is open, I can feel and hear the fan blowing. Even if my engine is cold.
It only turns off after say 40 km/h.
Old 07-27-2010, 07:18 PM   #9
drivetolive
I think the manuals came with an electrical fan while the auto/step trannies came with the clutch fan (which is what I have).
Also, surprisingly, I don't think the engine takes any longer to warm up.
BTW, when the hood is open, I can hear and feel the fan on (blowing air). Revving the engine causes the fan to go faster too (increasing noise).
BTW Eurostyle, I will give you a call tomorrow, got busy today (I called you in the afternoon but wasn't able to after that).
Old 07-27-2010, 07:51 PM   #10
Dr. Flyview
Formerly Flav_cool
Unless the mechanical clutch fan is radically different on an e46 than and e36, it would never really "turn off". It maintains a constant grip. In your case, it's too tight, spinning with the engine rpms. I don't think you can hear it past 40km/h because of the wind noise...
sold
Old 07-28-2010, 09:07 PM   #11
drivetolive
Got the issue all sorted out. Turned out to be a defective OEM clutch fan. Thanks to Rocco for the help!
Thanks for the responses.
